Trio Kenwood KA-2002 Japan Made stereo integrated amplifier
Trio Kenwood KA-2002 Japan Made stereo integrated amplifier Empty Trio Kenwood KA-2002 Japan Made stereo integrated amplifier
Post by HiFiLab on Thu May 14, 2020 7:45 pm
Trio Kenwood KA-2002 Japan Made stereo integrated amplifier 20200515
Trio Kenwood KA-2002 Japan Made stereo integrated amplifier 20200516
Trio Kenwood KA-2002 Japan Made stereo integrated amplifier 20200517
Trio Kenwood KA-2002 Japan Made stereo integrated amplifier 20200518
Price : RM 450
Made In Japan
In good working condition
Can use as Phono Preamplifier ( 2 X phono input for Turntable)
Can use as standalone pre amplifier
Kenwood's KA-2002 solid state stereo amplifier highlights all the best Hi-Fi features in compact size. Simply, yet tastefully, designed in appearance, liek all other Kenwood products, the KA-2002 puts quality above all else. Absolutely harmonious in the synchronized performance of all its units,
Special Features
Compact-sized Outside
Kenwood's technology and experience has minimized the high-quality stereoamplifier. Its weight is only 10,6 lbs. Its width is 13 inches only. You can handle KA-2002 as you like and position it where you like.
Condensed Inside
All silicon-transistorized circuits provide enough 46 watts IHF power (at 4 ohms) with less than 0,8% distortion and wide 20 - 30,000 Hz power bandwidth.
Precise Tone Control
For each bass and treble control the click type switches are used. They bring accurate increase/decrease by 10 dB (5 steps) each at 100 Hz and 10,000 Hz. The most suitable reproduction can be offered according to your performance or room acoustic condition.
Balance Control
The click stop is equipped at the center of balance Controller so that the «0» balance may be easily pointed out.
Push Type Switched
Loudness, Mode and Tape Monitor are controlled by newly developed, convenient push type switches.
Two Input Jacks for Phono
2 sets of stereo record player can be connected and selected by the switch on the front panel.
Total Power Output (both channel):
56 watts ±1 dB at 4 ohms
45 watts ± dB at 8 ohms
Total Dynamic Power (both channel, IHF):
46 watts at 4 ohms
38 watts at 8 ohms
Continuous Power Output (each channel driven):
19/19 watts at 4 ohms
17/17 watts at 8 ohms
Continuous Power Output (both channel driven):
15/15 watts at 4 ohms
13/13 watts at 8 ohms
Harmonic Distortion (from 20 Hz to 20,000 Hz):
0,8% at rated output
0,2% at -3 dB rated output
Intermodulation Distortion:
At rated output : Less than 0,8%
At -3 dB rated output : less than 0,2%
Frequency Response:
Main Input : 17 Hz to 50,000 Hz ±2 dB
High level Input (Aux) : 20 Hz - 30,000 Hz ±2 dB
Power Bandwidth (IHF): 20 - 30,000 hz
Input Sensitivity (for tared output at 8 ohms load):
Phono 1 : 2,0 mV
Phono 2 : 2,0 mV
Mic : 2,5 mV
Tuner, Aux, Tape : 150 mV
Main amp input : 100 mV
Input Impedance (at 1 kHz):
Phono 1 : 50 kohms
Phono 2 : 50 kohms (2,5 mV)
Aux : 50 kohms
Tape, Tuner : 50 kohms
Recording Output (below rated input):
Pin : 150 mV
DIN : 30 mV
Hum and Noise (below rated output):
Phono 1, 2 : 60 dB
Tuner, Tape : 70 dB
Aux : 70 dB
Damping Factor (at 8 ohms): 50
Speaker Impedance: accept 4 to 16 ohms
Loudness Control (at -30 dB):
+8 dB at 100 Hz
+4 dB at 10,000 Hz
Bass Control: ±10 dB at 100 Hz
Treble Control: ±10 dB at 10,000 Hz
Switches: Mode, Tape Monitor, Loudness, Selector (Aux, Tuner, Phono 1 and 2)
Semiconductors: 22 Transistors; 10 Diodes; 2 Thermistor
Power Requirement: AC 110 - 120 V, 220 - 240 V, 50/60 Hz
Power Consumption: 8 watts at no signals , 60 watts at full power
AC Outlets: 1 switched
Dimensions (W x H x D): 13'' x 4-5/8'' x 9-7/16''
Weight: 4,8 kg (10,6 lbs)
HiFiLab
Number of posts : 2734
