ART DJ Pre II Phono Preamplifier
ART DJ Pre II Phono Preamplifier Empty ART DJ Pre II Phono Preamplifier
Post by tongho on Tue Jun 02, 2020 11:27 am
Selling beloved DJ Pre II phono preamplifier RM150.00
Tel: +60122738893
ART DJ PRE II Phono Preamp with RIAA EQ in a Rugged Metal Case (DeeJayPre)
The DJ PRE II (formerly named the "Phono MicroPRE") acts as an interface between your turntable and your audio recording / playback system. The analog input capacitance can be switched between 100pF and 200pF to optimize your phono cartridge response. A switchable low cut filter removes turntable rumble while leaving the audio pristine. The front gain trim control and signal/clip LED allow you to optimize the preamp's gain for a wide range of input sources. The built-in low noise phono preamp circuitry is highly accurate and precisely conforms to the RIAA standard. The line output jacks are low impedance and can be used with any sound card.
Housed in an all aluminum black anodized case, the DJ PRE II can be powered by a wide variety of external supplies. If you need to amplify and EQ your vinyl records to interface with your audio workstation, sound card, home stereo system or main monitor system, the DJ PRE II gives you flawless audio reproduction in a rugged and reliable package.
FEATURES
- High accuracy/low noise preamp
- Switchable low cut rumble filter
- Variable preamp gain
- Signal present/clip indicator
- Selectable cartridge loading
- RCA preamp outputs
- Heavy duty extruded chassis
- Designed and developed in the USA
SPECIFICATIONS​
Preamp Type:Solid State
Number of Channels:2
Frequency Response:10Hz-50kHz (± .5dB)
Analog Inputs:2 x RCA (RIAA)
Analog Outputs:2 x RCA
Height:1.75"
Depth:3.5"
Width:4.2"
Weight:1.25 lbs.
Manufacturer Part Number:DEEJAYPRE II
ART DJ Pre II Phono Preamplifier Whats115
ART DJ Pre II Phono Preamplifier Whats116
tongho
Number of posts : 167
Amplification: Accuphase E470
Speakers: Quad z3
ART DJ Pre II Phono Preamplifier Empty Re: ART DJ Pre II Phono Preamplifier
Post by tongho on Tue Jun 09, 2020 9:14 am
tongho
Speakers: Quad z3
Post by tongho on Fri Jun 19, 2020 8:28 am
tongho
Speakers: Quad z3
Post by tongho on Fri Jun 26, 2020 4:40 pm
tongho
Speakers: Quad z3
