Musical Fidelity M1 PWR Power Amplifier
Item: Musical Fidelity M1 PWR Power Amplifier
Condition: 8.5/10. Item is in excellent condition. Looks very new. No dents or scratches.Comes with original power cord, manual and box. Extremely low usage.
Price: RM2500 or swap/topup
Retail USD1300
Click here to Whatsapp:
http://wasap.my/60123816611
Musical Fidelity M1PWR Power Amplifier
Plenty of Power plus Selectable Stereo/Mono Modes
The latest addition to the M1 series came from customer demand – they were clamouring for the perfect power amplifier partner for the award-winning M1 CLiC music controller.
After intensive technical development, we've delivered just that – and more – in the compact shape of the M1 PWR.
It's a premium performance mono/stereo power amplifier. A single M1 PWR offers 60 watts per channel of stereo drive, but at the slide of a switch it becomes a 100 watt monobloc. All circuitry is internally switched: all you need to do is connect up a second M1 PWR for an excellent, easy upgrade.
Even in its single-box mode it drives speakers with ease, delivering superb stereo separation and a punchy, pure sound. Add another M1 PWR and the performance steps up to another level again.
The svelte design and outstanding value of the M1 range means stacking up an amazing hi-fi system has never been easier, even if your space and budget are limited
https://www.musicalfidelity.com/m1pwr
https://www.kenrockwell.com/audio/musical-fidelity/m1pwr.htm
https://hometheaterreview.com/musical-fidelity-m1pwr-stereomono-amplifier/
Retail USD1300
Sometimes, good things come in small packages. Such is the case with the [size=16]Musical Fidelity M1PWR amplifier. No fancy name plates. No fancy chassis. No bells-and-whistles functions. Just a powerhouse high-end amplifier at a truly unbelievable price. This expectations-defying component provides plenty of power as well as selectable stereo or monoblock configuration. That's right: Use a single amp for 60 watts per channel, or utilize a pair as monoblocks for 100 watts into 8 Ohms or 200 watts into 4 Ohms. And, while supplies last, take advantage of this special opportunity to own this compact amplifier for $800 off the regular price!
A recipient of a Hi-Fi Choice Recommended honor, the M1PWR offers very low distortion, excellent frequency response, low signal-to-noise ratio, and incredible stereo separation. The forward-looking design means it produces little heat, goes easy on utility bills, and functions at peak efficiency at all times. If you face space constraints or have a partner that doesn't want stereo clutter, the M1PWR is a perfect solution without having to sacrifice musical quality.
Time and again, the M1PWR treats you to a sound prized for purity, cleanliness, detail, and airiness. It handles complicated recordings in which instruments and voices seem to be tangled by de-congesting the mix. Listeners that opt for a second unit and run two M1PWRs as monoblocks will be justly rewarded. We're awestruck at the dimensions, soundstages, and images these likable amps produce with such consistency and clarity.
Musical Fidelity has long been renowned for rich, powerful sounding amplifiers. Don’t miss this special chance to own one at a remarkable price. Comes with the Music Direct 100% satisfaction guarantee!
"The M1PWR sounds clean, fresh, and open, displaying a natural tonal balance and conveying a fine portrayal of dynamics. It is well-balanced and crisply detailed, giving the impression of having ample power in reserve. Tonally, it delivers a lean, lucid presentation of great clarity and transparency."
– Hi-Fi Choice,
"As a stereo power amp, the M1 PWR is a no-nonsense little belter, with plenty of power. As a pair of monoblocks, however, they really bring the music to life with superb imagery on a grand scale."
– HiFI News, Recommended Product[/size]
Performance
- Power output: Stereo Mode 65W into 8Ω, 130W into 4Ω, Mono Mode 100W into 8Ω, 200W into 4Ω
- THD(+ noise): Stereo <0.03%, Mono <0.02%
- Signal to Noise Ratio: Stereo >94dB, Mono >100dB
- Frequency Response: <0.5dB, (20Hz to 20kHz)
Inputs
- 1x RCA Phono Line Level
- 1x Trigger input 3.5mm (⅛”) mono jack ±4.5 to ±15V DC
General
- Dimensions - WxHxD (mm): 220 x 100 x 315
- Weight (unpacked / packed): 3.9 kg / 4.6 kg
» Musical Fidelity F22 Pre Amplifier + Musical Fidelity F15 Power Amplifier Made in England ( PL )
» Musical Fidelity F22 Pre Amplifier + Musical Fidelity F15 Power Amplifier (Made in England)
