JL Audio Dominion D110 Subwoofer Black Ash Finish - 750 Watt
JL Audio Dominion D110 Subwoofer Black Ash Finish - 750 Watt Empty JL Audio Dominion D110 Subwoofer Black Ash Finish - 750 Watt
Post by raymond88 on Sat Jul 04, 2020 5:03 pm
Item: JL Audio Dominion D110 Subwoofer Black Ash Finish - 750 Watt
Condition: New. With warranty. Last unit.
Price: RM5500 or swap/topup
Retail Price: RM8500
https://shopee.com.my/JL-Audio-Dominion-D-110-10-Inch-Powered-Subwoofer-(Black-Ash)-i.131198974.2764906687
Click here to Whatsapp:
http://wasap.my/60123816611
 When it comes to serving up intense, heart-pounding bass, JL Audio knows their stuff.
Read more from Crutchfield writer, Dave B.
JL Audio Dominion D110 Subwoofer Black Ash Finish - 750 Watt Jl210
JL AUDIO DOMINION D110
POWERED SUBWOOFER WITH 10-INCH SUBWOOFER DRIVER, 750 WATTS
Born from JL Audio’s vast collection of advanced technologies, Dominion powered subwoofers combine a state-of-the-art subwoofer driver and an advanced Class D amplifier to deliver unmatched performance and value for a wide variety of compact applications.
Purpose-built to reproduce powerful low-frequency events with stunning impact and precision, the Dominion driver employs JL Audio’s exclusive DMA (Dynamic Motor Analysis) technology to produce higher output levels with reduced distortion, as well as improved dynamic tracking and resolution. As a result, Dominion subwoofers are capable of peak-to-peak excursions well in excess of 2.5-inches (63 mm - d108), and 2.7 inches (68 mm – d110), without distress or audible distortion.
Dominion amplifiers utilize an advanced Class D design in order to extract the most from the long-excursion driver platform. This design features a tightly regulated switching power supply, allowing the amplifier to generate prodigious amounts of unclipped output voltages. These technologies ensure that the Dominion powered subwoofers remain in their comfort zone, which is well beyond the point where most small subwoofers run out of power or driver capability.
With a host of signal processing features included, Dominion powered subwoofers can be integrated into most systems with ease. Low-pass signals are precisely guided, thanks to the onboard crossover’s 24 dB/octave Linkwitz-Riley alignment. Phase and polarity controls are onboard to aid in achieving the optimal acoustic transition between the subwoofer(s) and main speakers. Flexible input options are on-hand to accept either line-level or speaker-level signals. Connect a JLINK TRX system (sold separately) to the onboard Wireless Link port and enjoy the freedom to position your Dominion almost anywhere, up to 100 feet (30 meters) away from your source unit.
To contain the immense pressures created by the Dominion driver, each beautiful cabinet is carefully engineered and constructed using solid, CNC-cut, MDF material with extensive internal bracing and advanced assembly techniques. All Dominion powered subwoofers are built with pride and precision in JL Audio’s U.S. factory to deliver years of listening enjoyment.
[size=20]SPECIFICATIONS[/size]
Frequency response (+/- 1.5 dB, -3 dB): 27 Hz to 111 Hz, 25 Hz to 118 Hz
Amplifier power: 750 W RMS short term
Inputs: 2 x RCA for stereo or mono, stereo or mono high level
Filter: Low pass, 24 dB/octave, defeatable, 25 Hz to 130 Hz
Polarity: 0 or 180 degrees
Phase: Variable, 0-280 degrees, referenced to 80 Hz
Line outputs: 2 x RCA for stereo or mono, high-pass or pass-through
Dimensions (WHD): 12" x 13.4" x 15.86"
Weight: 38.2 lb
JL Audio Dominion D110 Subwoofer Black Ash Finish - 750 Watt Jl310
https://www.youtube.com/watch?v=b1JdfVws_eM
https://www.youtube.com/watch?v=zbLozYnFKGE
https://www.soundandvision.com/content/jl-audio-dominion-d110-subwoofer-review
https://upscaleaudio.com/products/jl-audio-d110
https://www.jlaudio.com/products/d110-ash-home-audio-dominion-powered-subwoofers-96283
https://www.cnet.com/products/jl-audio-dominion-d110-subwoofer-96283/
Number of posts : 6500
JL Audio Dominion D110 Subwoofer Black Ash Finish - 750 Watt Empty Re: JL Audio Dominion D110 Subwoofer Black Ash Finish - 750 Watt
Post by raymond88 on Tue Jul 14, 2020 10:55 am
Post by raymond88 on Wed Jul 22, 2020 1:16 pm
Post by raymond88 on Fri Jul 31, 2020 1:21 pm
window.dataLayer = window.dataLayer || [];
function gtag(){dataLayer.push(arguments);}
gtag('js', new Date());
gtag('config', 'UA-172659890-2');
