Audio Technica AT91 MM Catridge
Audio Technica AT91 MM Catridge Empty Audio Technica AT91 MM Catridge
Post by Running_man on Fri Jul 10, 2020 10:09 am
The above for sale with the original stylus
Condition: Used, visual inspection 7.5/10 with stylus guard, no box
Buyer to note:
This is pulled from a used turntable recently purchased and have NOT been tested
Visual inspection did not reveal any apparent fault or damage to cantilever
Replacement stylus readily available from the internet (model ATN91)
https://eu.audio-technica.com/resources/A-T%20Phono_Cartridges_19_ENG_L00068_V3.0%20%28web%29.pdf
https://www.lpgear.com/product/AT91.html
Asking: RM80 (ono)
Contact: 0123689167 (Call or WA)
Will consider outstation sale, with stylus guard & size, packing will not be an issue
WA for photos
Full Specs from Audio Technica Website
TypeVM Dual Magnet
MountingHalf-inch
Frequency Response20 - 20,000 Hz
Channel Separation18 dB at 1kHz
Output Channel Balance2.5dB
Output Voltage3.5 mV (mV at 1 kHz, 5 cm/sec)
Vertical Tracking Angle20°
Vertical Tracking Force Range1.5 - 2.5g (standard 2.0g)
Stylus ShapeConical
Stylus Size0.6 mil
Stylus ConstructionBonded Round Shank
CantileverCarbon Fibre Reinforced ABS
Coil Inductance400mH (1kHz)
Static Compliance20x10-6cm/dyne
Dynamic Compliance6.5x10-6cm/dyne (100Hz)
Recommended Load Impedance47,000 ohms
Recommended Load Capacitance100-200 pF
Weight5.7 g
Replacement StylusATN91
Running_man
Running_man
Number of posts : 364
Registration date : 2013-07-09
Source(s): Kuzma
Amplification: VAC
Speakers: Rosso
Audio Technica AT91 MM Catridge Empty Re: Audio Technica AT91 MM Catridge
Post by Running_man on Wed Jul 22, 2020 11:01 am
Running_man
Running_man
Source(s): Kuzma
Amplification: VAC
Speakers: Rosso
Post by Running_man on Sat Aug 01, 2020 10:42 am
Running_man
Running_man
Source(s): Kuzma
Amplification: VAC
Speakers: Rosso
