Audible Illusions Modulus 2D USA Made Dual Mono Vacuum Tube Preamplifier With MM phono
Audible Illusions Modulus 2D USA Made Dual Mono Vacuum Tube Preamplifier With MM phono  Empty Audible Illusions Modulus 2D USA Made Dual Mono Vacuum Tube Preamplifier With MM phono
Post by HiFiLab on Mon Jul 27, 2020 7:15 am
Audible Illusions Modulus 2D USA Made Dual Mono Vacuum Tube Preamplifier With MM phono  20200753
Audible Illusions Modulus 2D USA Made Dual Mono Vacuum Tube Preamplifier With MM phono  20200752
Audible Illusions Modulus 2D USA Made Dual Mono Vacuum Tube Preamplifier With MM phono  20200754
Audible Illusions Modulus 2D USA Made Dual Mono Vacuum Tube Preamplifier With MM phono  20200756
Audible Illusions Modulus 2D USA Made Dual Mono Vacuum Tube Preamplifier With MM phono  20200755
Audible Illusions Modulus 2D USA Made Dual Mono Vacuum Tube Preamplifier With MM phono  20200757
Made In USA
Price : RM 3250
In good working condition
dual mono preamplifier
. It had dual volume controls on the front and took care to minimize the use of switching in the signal path along with careful circuit design preamplifier that posed some competition for the big bucks gear of the day.
Using just four 6DJ8/6922 tubes, two for the linestage and two for the built in phono section, the Modulus 2D was one of the best values in high end audio for quite some time.
the AI 2D sounded fantastic and in the day was the closest thing to a giant killer I had ever heard at that point. The dual volume controls were a bit of a pain and the high level inputs were limited, but it really sounded great!
This preamp had fantastic imaging and if you sprung for a fairly expensive set of 6922s it would really sing
HiFiLab
Number of posts : 2786
