Teac UD-501 digital analogue converter (sold)
2 posters
Hi,
i have no idea why my post got removed. btw, here's a repost.
i have a TEAC UD501 USB Digital analogue converter for sale. Condition 9/10 with original box and foam.
TEAC's UD-501 is the star of the 501 series. The UD-501 supports Direct Stream Digital (DSD) playback at either 2.8 MHz or 5.6MHz (DXD) rates. PCM audio is supported up to 384kHz/32-bit resolution. It connects to your computer over USB using ASIO 2.1 or DoP.
The output section of the UD-501 features two BurrBrown 32-bit DACs per channel and JRC MUSES op amps, also with a dual monaural design. Both balanced XLR and unbalanced RCA outputs are available to connect to your power amplifier. A toroidal-core power supply ensures top performance and clean transient playback, for quality that outperforms components five times its price
it's a full DUAL MONO design. with 2 transformer, 2 group of op amps, 2 separate DAC chip. this design has less cross talk they say.
The DAC is being upgraded further with the famous BURSON V5 dual op amp. review link below
https://www.bursonaudio.com/teac-ud-501-dac-burson-v6-opamp-upgrade/
https://www.head-fi.org/threads/teac-ud-501-upgrade-burson-v5-in-place-of-n5532a-review.804090/
asking price MYR SOLD negotiable.
i can be contacted at 012-3848732. MR Lim
Last edited by alchemis on Mon May 31, 2021 4:41 pm; edited 6 times in total (Reason for editing : don't know)
alchemis- Regular
- Number of posts : 78
Registration date : 2011-02-22
Re: Teac UD-501 digital analogue converter (sold)
lost count of days
Last edited by alchemis on Fri Aug 07, 2020 1:50 pm; edited 1 time in total (Reason for editing : don't know)
alchemis- Regular
And you are doing it again, Mr. Lim. This post will be removed also.
You must READ and ADHERE by the rules of the forum. You have 66 posts and one would imagine and hope that you would have read the rules at some point in the past. It appears you have chosen not to. You are not to all caps in your title, nor bump less than every 7 (SEVEN) days.
This is a good time to READ and ADHERE by ALL the rules right there on the front page of this forum. You will not be reminded again. Now that you know why your post was deleted, we, the admin, hope you will adhere by the rules. Any posts not adhering to the rules will be deleted without further communication.
Thank you.
Bal (moderator)
Thank you.
Bal (moderator)
bal- Moderator
- Number of posts : 1275
Speakers: maggie 1.7
» TEAC UD501 Digital Analogue Converter (SOLD)
» Teac UD-501 Digital to Analog Converter
» Teac UD-H01 DAC-Digital to Analogue Converter
» TEAC UD-H01 DAC-Digital to Analogue Converter
» TEAC UD-501 DSD 5.6MHz / PCM 384kHz capable Dual Monaural D/A Converter DAC (SOLD)
