Lii Audio W-15 Woofer
Lii Audio W-15 Woofer Empty Lii Audio W-15 Woofer
Post by HIFI Illiterate on Wed Aug 12, 2020 12:53 pm
This woofer is the outcome of a experimental development of open baffle with our Crystal-10 drivers. With superb bass performance, this W-15 can bring good bass even on narrow open baffles. It has a transparent tone so can bring a good coherence with most of the full rangers or tweeters & midrangers.
[list="margin-right: 0px; margin-bottom: 10px; margin-left: 20px; padding-right: 0px; padding-left: 0px; list-style-position: initial; list-style-image: initial; color: rgb(120, 125, 133); font-family:"]
[*]It uses short coil and super thick washer design, leading to very weakened distortion, 15mm Xmax for a good bass.
[*]With Lii Audio paper cone of unique material, it has a wide frequency response and transparent sound so that it can coordinate with a great variety of full range drivers.
[*]Double coil design let it competent to be adapted with amplifiers and connect in parallel or inseries with other driver units, according to impedance.
[*]The double coil makes it possible to be served as subwoofer, giving you more possibilities to play with these drivers.
[*]As Lii Audio driver developed by the same creator, this is a wonderful companion for other Lii Audio full range drivers, especially on open baffle.
[/list]
Specification,
1. Related power – Maximum power   100 – 150W
2. Nominal inpedance Z   8+8 Ohm
3. Frequency response   fu-5000 Hz
4. Mean sound pressure level   91dB(2.83V/1m)
5. Resonance frequency fs   28 Hz
6. Qts 0.79
Weight (pair in package)  27.5KG
Dimension (package) 54 x 54 x 57 cm
Price - RM2,500/pair
Contact - Terence, 0176028532
Remarks - We do custom build enclosure as well.
Lii Audio W-15 Woofer Lii-au12
[You must be registered and logged in to see this link.]Lii Audio W-15 Woofer Lii-au13
HIFI Illiterate
Number of posts : 748
Registration date : 2013-02-17
Source(s): Laptop with DAC
Amplification: Luxman Pre Power
Speakers: AcDynamics 3 Way Coaxial
https://www.facebook.com/acdynamics/
