Onkyo RZ720 7.2 Channel Network A/V Receiver (Used)
Onkyo RZ720 7.2 Channel Network A/V Receiver (Used) Empty Onkyo RZ720 7.2 Channel Network A/V Receiver (Used)
Post by choyaudiovisual on Wed Sep 02, 2020 12:18 pm
The TX-RZ720 offers THX Certified Select theater-reference sound and state-of-the-art features for breathtaking entertainment in the living room and beyond. Expect smooth and powerful 5 Hz–100 kHz reproduction with thrilling dynamics and exquisite detail rendition, whether you’re driving all channels with object-audio soundtracks or streaming music via Chromecast built-in*, AirPlay, or DTS Play-Fi:registered:*. Tap your touchscreen to share music to compatible speakers and components over FlareConnect:tm:*. HDMI:registered: now supports pass-through of HDR features including HLG (Hybrid Log-Gamma), Dolby Vision:tm:, and BT.2020 to the latest displays, while a suite of connections integrate the receiver into home automation systems.
Introducing the RZ Series
Our premium RZ Series A/V receivers deliver a significant boost to the dynamism, detail, and accuracy of music and movie soundtracks for a listening experience that packs deep emotional impact. The TX-RZ720 features quality components, such as large custom capacitors, to provide high instantaneous current for fast transients and wideband frequency response down to 5 Hz. Discrete non-phase-shift amp circuits clearly focus the audio image and cut distortion even at floor-shaking volumes.
THX:registered: Certified Select:tm: Reference Sound
THX Certified Select guarantees the same high-volume sound you experience at a commercial theater in your home. To gain certification, amplifiers must pass the industry’s most severe bench-tests covering every aspect of audio performance. THX Certified Select components are ideally suited to rooms where the screen-to-seat viewing distance is approximately 3 meters, and the room volume is approximately 57 cubic meters.
Unleash Dolby Atmos:registered: or DTS:X:registered: Home Theater
Object-based soundtracks allow independently mixed sound to play through any speaker in your system, moving above and around you with breathtaking realism. The TX-RZ720 reproduces 5.2.2-channel Dolby Atmos or DTS:X formats, with AccuReflex correcting the phase of direct and indirect sounds for cohesive audio imaging with Dolby Atmos-enabled speakers.
Onkyo Controller Supports Next Generation Network Audio
Onkyo Controller collects streaming services and local network audio into an intuitive app. Control playback, explore services, and distribute audio all over the home via FlareConnect powered by Blackfire from one interface.
Music Made Easy with Chromecast built-in*
Stream any music from your smartphone, laptop, or PC to the TX-RZ720 with ease. Control playback with Chromecast-enabled apps you know and love from your iPhone, iPad, Android:tm: phone or tablet, Mac or Windows:registered: laptop, or Chromebook:tm:.
Ready for DTS Play-Fi:registered:* Multi-room Audio
DTS Play-Fi allows you to enjoy high-quality music from connected online services, networked media servers, and your device library over Wi-Fi:registered: to any number of compatible products using the Onkyo Music Control App for iPad, iPhone, and Android:tm: smartphones/tablets. DTS Play-Fi can synchronize the music in every room. Each member of your family can use their own device to listen to their own music in their room or group of rooms. DTS Play-Fi lets you easily structure a comprehensive multi-room ecosystem that satisfies virtually any need.
FlareConnect:tm: Wireless Multi-room Audio
FlareConnect* shares audio from network and external audio input sources between compatible components. Enjoy effortless multi-room playback of LP records, CDs, network music services, and more with supported components and speaker systems. Music selection, speaker grouping, and playback management across the home are built into the Onkyo Controller** app.
Wi-Fi:registered:, AirPlay, Spotify:registered:, and Bluetooth:registered:
Selectable 5 GHz/2.4 GHz Wi-Fi:registered: assures a stable connection so you can stream over AirPlay, the Spotify app, and the local network. Bluetooth wireless technology provides simple streaming from your choice of app.
Internet Radio and Streaming Services
TIDAL, Deezer(Deezer HiFi*), and TuneIn are on board to make selecting from a massive range of music and radio programs using Onkyo Controller very simple.
Supports HDR10, HLG, Dolby Vision:tm:, BT.2020, 4K/60 Hz, and HDCP 2.2
Six rear HDMI:registered: inputs, Main Out, and Zone 2 Out support pass-through of HDR10, HLG (Hybrid Log-Gamma), and Dolby Vision; the BT.2020 4K video standard; 4K/60 Hz video playback; and HDCP 2.2 for premium video content. Front HDMI terminal is ideal for video camera connection, while the Zone 2 output distributes home theater video to a display in a second room.
Upmixing Solutions for Legacy Soundtracks
DTS Neural:X:tm: identifies spatial effects in multichannel soundtracks and upmixes for 3D playback through object-audio-ready speaker systems. Dolby Surround also upmixes legacy sound formats so you can experience multidimensional playback of legacy sound formats in a Dolby Atmos environment.
Conditions: 9/10 (USED)
Price: RM2500 inclusive postage to West Malaysia
Whatsapp: Choy 012-5685484
Onkyo RZ720 7.2 Channel Network A/V Receiver (Used) Whatsa67Onkyo RZ720 7.2 Channel Network A/V Receiver (Used) Whatsa68Onkyo RZ720 7.2 Channel Network A/V Receiver (Used) Whatsa69
Number of posts : 2056
Onkyo RZ720 7.2 Channel Network A/V Receiver (Used) Empty Re: Onkyo RZ720 7.2 Channel Network A/V Receiver (Used)
Post by choyaudiovisual Today at 9:22 am
