SVS SB-2000 Pro Subwoofer, 3 Years Warranty
SVS SB-2000 Pro Subwoofer, 3 Years Warranty Empty SVS SB-2000 Pro Subwoofer, 3 Years Warranty
Post by actsessory on Thu Sep 17, 2020 8:06 pm
*Latest SVS series
*550 watts RMS (1500w Peak Dynamic)
*SVS 12″ high-excursion driver
*Sealed, Compact Cabinet
*Sledge amplifier STA-550D, fully discrete MOSFET output
*Deep low frequency extension of 19Hz – 240Hz
*3-Years Warranty
Room-filling output and low frequency extension below 20 Hz with audiophile refinement and musicality.
SVS SB-2000 Pro Subwoofer, 3 Years Warranty Sb2k-p
SB-2000 Pro brings reference subwoofer performance to more people than ever from a compact cabinet measuring only 15-inches on all sides.
Harnessing the massive power while ensuring unerring control and room-energizing bass response is a 50 MHz Analog Devices Audio DSP.
SB-2000 Pro also features the SVS subwoofer smartphone app for convenient control of volume, DSP functions, custom presets and more.
Jaw-dropping deep bass extension and massive output with stunning musicality that will delight both audiophiles and home theater fans.
SVS SB-2000 Pro Subwoofer, 3 Years Warranty Sb2k-p2
Completely redesigned 12-inch SVS driver delivers massive low frequency output with unerring accuracy and transient speed.
Dual ferrite magnet motor assembly weighing over 15 lbs generates massive amounts of magnetics to produce extreme driver excursion without losing control.
Lightweight and rigid aluminum vented cone with composite fiber dustcap creates room-energizing SPLs while maintaining control even at the highest drive levels.
Long-throw parabolic surround using proprietary injection molding allows extreme excursion for bass you can feel while preserving drive unit longevity.
Aluminum pole piece extension improves thermal management properties for exceptional heat dissipation.
Dual layer voice coil design maximizes linearity and accuracy at full excursion while minimizing distortion and power compression.
SVS SB-2000 Pro Subwoofer, 3 Years Warranty 2000pro_driver_3__large_full
-550 watts RMS continuous (1500+ watts peak dynamic)
-Sledge STA-550D DSP amplifier
High Current Output from Fully Discrete MOSFETs with Efficiency of Class D Amplifier allows the Sledge STA-550D amplifier to move massive amounts of current enabling immense output with surgical precision.
Sophisticated 50Mhz High Resolution Analog Devices Audio DSP is the most advanced digital Processor ever used in a subwoofer and maintains pinpoint accuracy and pristine sound quality through advanced in-room tuning, powerful DSP controls and more.
SVS SB-2000 Pro Subwoofer, 3 Years Warranty Pb2000-pro4
-Freq Response: 19-240 Hz +/- 3 dB
-Expect 2-3 Hz deeper extension in small to mid-size rooms.
-Protective non-resonant extra-thick ABS fabric mesh grill
SVS SB-2000 Pro Subwoofer, 3 Years Warranty Sb2000p1
SVS SB-2000 Pro Subwoofer, 3 Years Warranty Sb2k-p1
SVS SB-2000 Pro Subwoofer, 3 Years Warranty Sb3000acjpg
Smartphone App – Easiest Way Ever to Manage Subwoofer DSP and Control.
3 custom presets – one-touch tuning optimized for music, movies, gaming, and more.
2-way feedback show updates in real time (app and rear panel of subwoofer)
Connects via Bluetooth
3-band parametric EQ controller
Adjust rossover frequencies, 3-band parametric EQ, polarity, room gain and more, all from your favorite seat.
SVS Intelligent Control Interface (ICI) on the rear panel of the 2000 Series cabinets provide control options for the subwoofer’s most critical functions.
Cabinet Dimensions: 14.6” (372mm) H X 14.2” (360mm) W X 15.6” (395mm) D (with grille)
Weight: 17.5kg
Product info: [You must be registered and logged in to see this link.]
3 Years Local Warranty
Price:  RM4999 (Black Ash); RM5499 (Piano Black)
Location at Subang Jaya SS14
**Credit Card accepted.
Contact 0126116917
actsessory
Number of posts : 1805
http://www.actsessory.com
