McIntosh HT-12 USA Passive 12 inch Subwoofer
Price : RM 2250
MADE IN USA
HT-12 Home Theater Subwoofer
While powered home theater subwoofers are excellent,
the HT-12 passive subwoofer gives the dedicated home theater
enthusiast the added ability to select the quality and power of the amplifier.
This 12" design uses a high efficiency driver so that even the smallest McIntosh amp can drive it to room-filling sonics.
The patented LD/HP
The driver in the HT-12 can easily handle up to 400 watts. Capable of powerful bass output across a range from 29Hz to 500Hz, the
McIntosh HT-12 will provide the kind of chest pounding foundation on which a modern digital soundtrack is often built.
Paired with a high quality McIntosh amp, the HT-12 is your ticket to earth-shaking home theater.
Specifications:
12" Subwoofer
Designed for low distortion reproduction
12" extended excursion driver with patented
LD/HP
Shielded magnetic field for safe placement near video monitors
Vibration-resistant enclosure
Passive design
Gold-plated connectors
Black Ash finish
DRIVER COMPLEMENT: 12 inch LD/HP
IMPEDANCE : 4 ohm nominal
FREQUENCY RESPONSE : 29Hz - 500Hz +3dB (close microphone)
SENSITIVITY : 86dB (2.8V/1m, ground plane)
POWER HANDLING : 400 watts maximum
DIMENSIONS (H X W X D)
17" (43.18cm) height, add 1/2" (1.27cm) for feet; 17" (43.18cm)
width; 17" (43.18cm) depth, add 1" (2.54cm) for grille
FINISH : Black Ash
WEIGHT (EACH) : 75 lbs (34.02 Kg) net; 83 lbs (37.65 Kg) in shipping carton
- Number of posts : 2866
Up
