Audio Research LS3 Line Stage Pre-Amplifier, USA
Finely crafted and finished.
Designed to last, through its elegant engineering design, selection of quality components, intelligent and caring manufacture.
Shortest-signal-path layot with minimum of point-to-point wiring.
Patented Decoupled Electrolytic Capacitor circuit, found in more expensive Audio Research products
D.C.-coupled inputs
Tightly regulated power supply
Direct Gain Path, bypasses all controls and switching functions
2 sets of single-ended outputs for 2 separate power amps in a bi-amped system
Stereophile Class “A” Recommended Components Line Stage.
Touted to be even better than the LS2. “..the LS3 appeared to replicate the overall performance of the LS2, and then some…”
by Martin Colloms, Stereophile Magazine Vol 16 No. 8
Audio Research LS3 preamp runs silently without coloring the music especially at low volumes.
It has great depth and detail.
The LS3 is stunning in its clarity, detail and utter simplicity.
From small ensemble baroque to big symphonic pieves, LS3’s performance is beyond reproach.
Voices are lifelike, smooth and clear.
The detail runs deep into music and every single instrument on recordings is clear and well separated.
It reproduces astounding resolution of musical detail, with wide-open dynamics.
Great tight bass, real midrange and detailed highs.
Dimensions: W480 x H134 x D260 mm (Standard rack panel)
Weight : 5.0kg
Detail spec: https://www.arcdb.ws/model/LS3
User Manual: https://www.arcdb.ws/Database/LS3/AC_LS3_LS3B_manual.pdf
Great and clean condition, all levers and knobs are intact.
Perfect working.
Made in USA, 120V version.
RM3400
*Credit cards accepted.
Subang Jaya ss14
Contact 012 6116917
https://www.facebook.com/Actsessory
