Consonance Tristan Integrated Amplifier
Consonance Tristan Integrated Amplifier Empty Consonance Tristan Integrated Amplifier
Post by peterclting on Wed Oct 14, 2020 6:39 pm
Consonance Tristan Integrated Amplifier for sale.
Condition is 8/10, working fine.
100watts per channel into 8 ohm.
Selling RM1890
Contact Peter 012-3820333
Specs
- 100 watts output power per channel
- LED display equipped
- Relay switched input source selector
- Digitally controlled active preamp stage
- Cool Class A technology applied in amplifier stage
- High quality MM/MC phono stage employed
Specifications:
Power output: 100W +100W at 8 Ohms
Minimum load: 4 ohms speakers can be connected.
Inputs: 4 selectable inputs switched by gold plated relays
Input Terminals: Gold plated Phono/RCA unbalanced
Phono input: (MM,MC) selectable
Frequency response: - 0.5 dB deviation 2Hz-80kHz
Signal-to-noise ratio: More than 95dB
Input Sensitivity: 300mV
Distortion: Less than 0.02% ( 70W 8 0hms)
Remote Control: Philips RC-5 compatible IR system 36kHz modulation frequency
Dimensions/Weight: 11cm x 45cm x 40cm (HxWxD) / 22kg
Consonance Tristan Integrated Amplifier Img_6110
Consonance Tristan Integrated Amplifier Img_2518
Consonance Tristan Integrated Amplifier Img_6111
peterclting
Number of posts : 897
