Klipsch KG 5.2 BiG Floorstand speaker
Klipsch KG 5.2 BiG Floorstand speaker Empty Klipsch KG 5.2 BiG Floorstand speaker
Post by HiFiLab on Sun 08 Nov 2020, 12:35 pm
Klipsch KG 5.2 BiG Floorstand speaker 20201047
Klipsch KG 5.2 BiG Floorstand speaker 20201045
Klipsch KG 5.2 BiG Floorstand speaker 20201046
Klipsch KG 5.2 BiG Floorstand speaker 20201049
Klipsch KG 5.2 BiG Floorstand speaker 20201048
Klipsch KG 5.2 BiG Floorstand speaker 20201050
Made In USA
Price : RM 2450
Contact SiMon Ting 012-3612507
The two-way KG Series KG 5.2 floorstanding loudspeaker was first introduced in 1992 and manufactured by Klipsch until 1994.
Specifications:
Frequency Response: 34Hz-20kHz(+-)3dB
SENSITIVITY: 96dB 1watt/1meter
POWER HANDLING: 100 watts maximum continuous (500 watts peak)
NOMINAL IMPEDANCE: 8 ohms
TWEETER: K-85-K 1" (2.54cm) Phen
WOOFER ACTIVE: K-1001-K 10" (25.4cm) ICG cone
WOOFER Passive radiator 12 inch
ENCLOSURE MATERIAL: Medium density Lfiberboard construction (MDF)
ENCLOSURE TYPE: Bass reflex via passive radiator
DIMENSIONS: 33.5" (85.1cm) x 14.75" (37.5cm) x 12.75" (32.4cm)
WEIGHT: 54 lbs. (24.5kg)
Finished Black
Built From: 1992
BUILT UNTIL: 1994
HiFiLab
Number of posts : 2840
