SOLD SVS SB13-Ultra 1000 Watt DSP Controlled 13" Compact Sealed Subwoofer (Piano Gloss Black)
Item: SVS SB13-Ultra 1000 Watt DSP Controlled 13" Compact Sealed Subwoofer (Piano Gloss Black)
Condition: 8.5/10. Item is in LIKE NEW condition. No dents or scratches. Comes with original front grill.
Price: sold
Click here to Whatsapp:
http://wasap.my/60123816611
Add powerful bass to your home entertainment experience with the piano gloss black SVS SB13-Ultra 13.5" 1000W Subwoofer. It uses a 13.5" front-firing woofer to produce up to 1000W of RMS power and up to 3600W of peak power for ground-shaking performance in nearly any listening environment. With a frequency response of 20 to 460 Hz, the SB13-Ultra is equipped to handle virtually all types of listening material.
Front-firing 13.5" driver
Protective non-resonant steel mesh grille
MDF (Medium-Density Fiberboard) cabinet enhances rigidity
Detachable power cord
13.5" Ultra-series driver optimized for sealed applications
Die-cast aluminum basket
Flat-wire, 3" diameter, 8-layer aluminum voice coil
Polyimide-impregnated fiberglass former/bobbin
Dual 9", composite-layered, linear-roll, high-excursion spiders
Integrated tinsel leads
Nickel-plated spring terminals
Injection-molded gasket and parabolic SBR enhanced-excursion surround
Composite pulp/fiberglass press-layered cone with stitched surround
Low-carbon 1008 steel components and electrophoresis black plating
FEA-optimized overhung motor structure with a custom gap extension plate designed to enhance force/displacement symmetry, lower distortion, and increase linear stroke
Copper shorting sleeve reduces gap induction and distortion and enhances thermal conductivity
Dual Genox 8H/Y-35 ferrite magnets
Oversized pole vent for improved cooling and reduced noise
1000W RMS continuous, 3600W peak dynamic power
Class D topology designed for efficiency and cool-running
Detachable power cord with a main power switch and ceramic fuse
RoHS compliant, lead-free construction, and worldwide safety certifications
Auto-On / On switch with "green" standby mode
Stereo line-level RCA and balanced XLR input/output connections
Normal and Hi input voltage switch
Fully adjustable (frequency and slope) phase-correct speaker/sub digital crossover
EQ and DSP limiter settings
IFC (Intelligent Feature Control) with an LCD display
Two digital PEQs with adjustable frequency, cut/boost, and Q values
Room gain compensation control with adjustable frequency and slope
Adjustable digital delay on main speaker line-level outputs to time-align the speakers and subs
https://www.svsound.com/products/sb13-ultra
https://www.hifix.co.uk/svs-sb13-ultra-subwoofer
https://www.soundandvision.com/content/svs-sb13-ultra-subwoofer
Item: Onkyo DXC390 Six CD Carousel Changer
Condition: 8.5/10. Item is in like new condition. Comes with original remote control
Price: RM900 or swap/topup
Retail Price: RM1990
https://malaysia.desertcart.com/products/876643-onkyo-dxc390-6-disc-cd-changer
https://www.hifix.co.uk/onkyo-dxc390-six-cd-changer
https://www.intl.onkyo.com/products/hi-fi_components/cd_players/dx-c390/index.html
Item: Pioneer Elite N-30 Audiophile Network Audio Player with AirPlay & DLNA 1.5
Condition: 8.5/10. Item is in excellent condition. Comes with original remote control and power cord. Item brought back from US. It comes with stepdown power adaptor.
Price: RM1300 or swap/topup
Retail Price: RM2490
Now music enthusiasts have an exceptional new component to be
enthusiastic about. The Pioneer Elite N-30 Network Audio Player.
With its ability to download at up to 7 times the quality of
cd’s, the N-30 stylishly allows you access to online audio
content from any room in your house. Connecting to your home
network, you can enjoy a wide variety of online music services
remotely.
[color:2d3f=rgba(0, 0, 0, 0.870588235294118)]
https://malaysia.desertcart.com/products/5520367-pioneer-elite-n-30-audiophile-network-audio-player-with-air-play-dlna-1-5
https://www.hifix.co.uk/pioneer-n30-network-audio-streamer
https://www.cnet.com/reviews/pioneer-n-30-review/
Item: Audioengine D2 24-BIT Wireless USB DAC (Remote-output 24-bit/96kHz DAC)
Condition: 8/10. Item is in good working condition
Price: RM950 or swap/topup
Retail Price: USD599
[size=16]What is it and how to use?? Watch below video
https://www.youtube.com/watch?v=zuuaBE7277A
[/size]
Read more from Crutchfield writer, Dave B.
https://audioengineusa.com/product_tech_specs/d2-24-bit-wireless-dac/
https://www.kenrockwell.com/audio/audioengine/d2.htm
https://www.crutchfield.com/S-7SmFUNxjAlO/p_772D2/Audioengine-D2.html
Item: JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit
Condition: New. Last 2 sets
Price: RM1299 or swap/topup
JL Audio JLink TRX Wireless Kit
JL Audio's JLINK TRX Wireless, High-Fidelity Audio Transmitter & Receiver Kit adds wireless capability to a powered subwoofer in seconds. Simply connect the JLINK transmitter to your home theater receiver's subwoofer output. Then plug the JLINK's receiver module into your sub. The kit's 100-foot wireless range gives you the freedom to place your sub anywhere you like without the need to run long interconnect cables across your floor. Plus, the transmitter and receiver modules' compact size make them easy to hide.
The JLINK TRX isn't just limited to subwoofers. It can be used to wirelessly connect any two line-level audio devices together. For example, you can send crystal-clear, full-range stereo sound from a source component like a CD player to your receiver or a pair of powered speakers across the room, or throughout your home. Each transmitter can support up to four receivers (additional receivers sold separately). Think of the possibilities. Each kit comes with AC power supplies for the transmitter and receiver. And if you have a JLINK compatible JL Audio subwoofer, you can use its built-in JLINK port to make a handy single-wire power and audio connection to the receiver using the supplied JLINK cable.
READ LESS
JL Audio JLINK:tm: TRX High-Fidelity Audio Transmitter & Receiver Kit owner's manual
https://www.youtube.com/watch?v=_X6JpXeoyXg
https://www.jlaudio.com/products/jlink-trx-home-audio-wireless-kit-96102
https://www.crutchfield.com/S-xN2s7fj4esI/p_136TRX/JL-Audio-JLINK-TRX-High-Fidelity-Audio-Transmitter-Receiver-Kit.html
https://www.paragonsns.com/products/jl-audio-jlink-trx
[color:2d3f=rgba(0, 0, 0, 0.870588235294118)]***************************************
Price: sold
Subwoofer Features
Driver Features
Amplifier Features
[size=18]UP TO 6 DISCS FOR HOURS OF MUSIC TO SET YOUR LIFE TO[/size]
Music lovers rejoice! Those looking for the ultimate in CD playback from an audiophile grade component will be impressed with high-precision VQA (Vector Quantizer Audio DAC Technology) and 128 x oversampling. Others looking for convenience will thrill at the sight of 6-disc capability, 6 repeat modes, 40 track programming and no worries about interruptions to your music with the ability to change 5 discs while the last one is still playing. All will marvel at crystal clear playback enhanced by our exclusive VLSC (Vector Linear Shaping Circuitry) for a smoother sounding audio signal and Direct Digital Path, a heavily shielded, high-quality cable to protect that same delicate audio signal from noise emitted by the surrounding circuits. Housed in a sturdy chassis graced with a brushed aluminum front panel, the DX-C390 is ready to provide hours of uninterrupted music for the soundtrack to your life.6-Disc Carousel Design
Six bays translates to six discs at a time. Even while one disc is playing, you can load and remove the other discs without interrupting playback. The format of each loaded disc is conveniently displayed as an icon on the front display. The ultra-quiet, efficient loading mechanism makes changing discs a simple exercise.VLSC:tm: (Vector Linear Shaping Circuitry)
Conventional D/A conversion methods reduce digital pulse noise at the conversion stage but can't remove it completely. VLSC employs a unique D/A conversion circuit to overcome this problem. Data is converted between sampling points and these points are joined with analog vectors in real time to produce a smooth output wave form. The result—a virtually noiseless, smooth, analog signal based on the digital source that brings out even the most subtle of nuances in music sources (including DVD-Audio and Super Audio CD), DVD Video sources (including high-definition), broadcasts, digital music files such as MP3s, and gaming content.Website:
Description
- Pioneer Elite Audiophile Networked Audio Player featuring Air Play and DLNA 1.5.
- No Setup or Pairing Required - Air Play uses existing Wi-Fi Network.
- View Album Art and Metadata on Music Tap's full-color 2.5" screen.
- vTuner Internet Radio; iPhone or Android Control App.
- EL Transformer; Made for iPod, iPhone Certified with USB Connection.
- Imported from USA.
remotely.
[/size]
If you store your music on a computer, the Audioengine D2 wireless DAC makes it easy to transmit audiophile-quality...
[color:2d3f=rgba(0, 0, 0, 0.870588235294118)]Read more from Crutchfield writer, Dave B.
"REVIEWERS' CHOICE" AWARD WINNER, SOUNDSTAGE.COM
"ONE OF THE BEST"
Audioengine's D2 24-bit wireless DAC allows you to stream wireless HD audio from your computer to any music system, independent of your Wi-Fi network. D2 includes USB and optical inputs, a high-performance DAC, plus the isolation benefits of wireless. Set-up is fast and simple, with no software to install and without the frustration that can come from trying to connect to your network.
"The Audioengine D2 is not only one of the most innovative products I’ve reviewed in a long time, it’s also one of the best," raves Doug Schneider in his April 2012 review for Soundstage.com, which honored the D2 with a "Reviewers' Choice" award. "The fact that it’s so affordably priced makes this game-changing DAC all that much easier to buy."
"At any price, the Audioengine D2 is a great DAC," notes Ken Rockwell in his February 2012 review for KenRockwell.com. "It also has an excellent volume control to let you completely bypass a preamplifier for even better sound."
"The Wireless Part Is Just a Splendid Bonus"
"This DAC sounds great, and the wireless part is just a splendid bonus," reports Dean Seislove in Issue 60 of PositiveFeedback. "Audioengine has delivered yet another excellent audio product at a very competitive price."
"The plug-and-play Audioengine D2 is fun to use, is super reliable, is affordable, and sounds great. Admit it: you want one," says Tom Lyle in his April 2012 review for EnjoyTheMusic.com.
Game-Changing Computer Audio
The D2 offers audio fidelity and features of DACs costing several times more, but with one very important feature - it's wireless! D2 is a simple to use yet powerful digital-to-analog converter with performance and features generally found in much more expensive DACs. The D2 processes digital audio at any bit depth up to 24 bits and sample rates to 192 kHz, then sends your music over-the-air at 24/96. It accepts USB or PCM-stereo optical digital and will automatically configure to match either of these inputs.
Easy Setup and Simple Operation
Bypass your computer's sound card or headphone jack and send wireless HD audio to any music system. D2 transmits all music file formats from any computer media player and can simultaneously transmit HD audio to up to three D2R wireless receivers. The 100ft typical range, low latency, built-in DAC, and resistance to interference and dropouts makes D2 a great-sounding HD wireless system.
Want music in more than one room of your house or apartment? Just add more D2R wireless receivers.
Digitally Versatile
The D2 is actually three products in one. It's a high-quality USB wireless computer DAC, a wireless USB-to-SPDIF converter, and a wireless optical PCM-to-stereo link. The ability to stream HD audio wirelessly from your computer direct to your music system not only keeps your computer away from your audio gear, but it also minimizes nagging problems such as ground loops, induced cable noise, and jitter. And if you already have a favorite DAC, the D2 can provide bit-perfect wireless USB-to-SPDIF conversion or serve as a wireless link for your PCM-stereo stream.
Data Integrity is Assured
The D2 sends a 24-bit, 96 kHz PCM stereo digital stream over-the-air in a 'closed-system' Wi-Fi configuration. The system's proprietary RF technology ensures data integrity with no impact on existing routers or networks. The volume control on the D2 Sender is transmitted over an entirely separate channel so there is no impact on the digital audio stream.
See and Hear the Difference
Audioengine designers, with their attention to audio quality as well as visual aesthetics, have created a feast for both the eyes and ears. The rounded anodized aluminum case of the D2 reflects traditional Audioengine design and the audio fidelity is typical of Audioengine's commitment to great sound at an affordable price. The Audioengine D2 continues to close the gap between your computer music and home hi-fi and even if you're not an audio enthusiast we guarantee your music will sound better!
[color:2d3f=rgba(0, 0, 0, 0.870588235294118)]Website:
Unleash your sub or other audio gear with this wireless kit
[color:2d3f=rgba(0, 0, 0, 0.870588235294118)]JL Audio's JLINK TRX Wireless, High-Fidelity Audio Transmitter & Receiver Kit adds wireless capability to a powered subwoofer in seconds. Simply connect the JLINK transmitter to your home theater receiver's subwoofer output. Then plug the JLINK's receiver module into your sub. The kit's 100-foot wireless range gives you the freedom to place your sub anywhere you like without the need to run long interconnect cables across your floor. Plus, the transmitter and receiver modules' compact size make them easy to hide.
READ LESS
Product highlights:
- includes wireless transmitter and receiver for use with powered subwoofers
- compatible with any brand of subwoofer or other audio gear with mono or stereo RCA connections
- 16-22,000 Hz frequency response for outstanding fidelity in subwoofer and full-range applications
- 16-bit/48 kHz bit-perfect digital PCM stereo wireless technology
- wireless range: up to 100 feet
- operates on 2.4GHz wireless band
- receiver includes JLink port and cable for use with compatible JL Audio products
What's in the box:
[color:2d3f=rgba(0, 0, 0, 0.870588235294118)]JL Audio JLINK:tm: TRX High-Fidelity Audio Transmitter & Receiver Kit owner's manual
- Wireless transmitter
- Wireless receiver
- 2 AC power adapters (w/ attached 59" DC cords)
- 39" JLINK cable
- 2 Hook-and-Loop fasteners
- User Manual
shan likes this post
» SVS SB13-Ultra 1000 Watt DSP Controlled 13" Compact Sealed Subwoofer (Piano Gloss Black)
» Sumiko S.9 Subwoofer by Sonus Faber- Gloss Piano Black
» SVS SB13-Ultra Subwoofer (SOLD)
» SVS SB13-Ultra Subwoofer ( sold )
» SVS SB13-Plus active sealed subwoofer (used)
