SMSL SU-8 v2 Hi-Res DSD DAC (Price Reduce)
Condition: 9/10 Excellent
Still Under Warranty
Prices: RM650 Negotiable.
Calls or Whatsapp: Mr. Koay 013-3531188
HiFi Decoder SMSL SU-8 2ES9038Q2M USB PCM32 768kHz DSD64 DSD512 DSD Balance DAC Decoder
ESS technology latest ES9038Q2M DAC, with the new 32-bit HyperStream II architecture, improving sound quality and DoP function.
2nd generation of XMOS USB audio solution xCore200, PCM sampling rate supported up to 32bit/768kHz and DSD up to DSD512.
Ultra-low jitter asynchronous design and using ultra-low phase noise crystal as audio clock.
Every input port supported DSD streaming, coaxial and optical supported to DSD64 by DoP technology via 24bit/176.4kHz SPDIF frame.
There is 9 types of Sound color setting, not the digital filters, this feature using the DSP of ES9038Q2M to adjust the level
of 2nd and 3rd distortion, make it sounds different.
Specification:
Input :USB / Optical / Coaxial
Output:RCA , XLR
Output Level:2Vrms(RCA) ,4Vrms(XLR)
THD+N:0.0003%
Dynamic range:120dB
SNR:116dB
USB compa bility:Windows 7 / 8 / 8.1 / 10 Mac OSX10.6 or Later / Linux
Bit depth:
USB:1bit-32bit
Optical/coaxial:1bit-24bit
Sampling rate:
USB:PCM:44.1-768kHz DSD:2.28224-22.5792MHz
Optical/coaxial:32-192kHz DSD64(DoP)
Consumption Power:3W
Standby power:<0.1W
Weight 1.0kg
Remote control:
Install 2 x AAA batteries as instruction
When using the remote control, point it toward the remote con-trol signal receiver on the main unit from a distance of 5 m (16 ft)
or less. Do not place obstructions between the main unit and the remote control.
The remote control might not work if the remote control signal receiver on the unit is exposed to direct sunlight or bright light.
If this occurs, try moving the unit. Beware that use of this remote control could cause the unin-tentional operation of other devices
that can be controlled by infra.
Specification:
Output:RCA , XLR
THD+N:0.0003%
Dynamic range:120dB
SNR:116dB
Bit depth:
USB:1bit-32bit
Sampling rate:
Standby power:<0.1W
Weight 1.0kg
Remote control:
Jason Eng- New Member
- Number of posts : 23
Registration date : 2020-09-09
Re: SMSL SU-8 v2 Hi-Res DSD DAC (Price Reduce)
Jason Eng wrote:SMSL SU-8 v2 Hi-Res DSD DAC
Prices: RM750 Negotiable.
Specification:
Output:RCA , XLR
THD+N:0.0003%
Dynamic range:120dB
SNR:116dB
Bit depth:
USB:1bit-32bit
Sampling rate:
Standby power:<0.1W
Weight 1.0kg
Remote control:
Specification:
Output:RCA , XLR
THD+N:0.0003%
Dynamic range:120dB
SNR:116dB
Bit depth:
USB:1bit-32bit
Sampling rate:
Standby power:<0.1W
Weight 1.0kg
Remote control:
