Marantz CD60 Belgium Made Stereo CD player TDA -1541A DAC with remote
Marantz CD60 Belgium Made Stereo CD player TDA -1541A DAC with remote Empty Marantz CD60 Belgium Made Stereo CD player TDA -1541A DAC with remote
Post by HiFiLab on Mon Nov 23, 2020 7:43 am
Marantz CD60 Belgium Made Stereo CD player TDA -1541A DAC with remote 20201111
Marantz CD60 Belgium Made Stereo CD player TDA -1541A DAC with remote 20201112
Marantz CD60 Belgium Made Stereo CD player TDA -1541A DAC with remote 20201110
Marantz CD60 Belgium Made Stereo CD player TDA -1541A DAC with remote 20201115
Marantz CD60 Belgium Made Stereo CD player TDA -1541A DAC with remote 20201113
Marantz CD60 Belgium Made Stereo CD player TDA -1541A DAC with remote 20201114
Price : RM 1150
Made In Japan
In Good working Condition
Description�@
The compact disk player which inherited the technology and know-how of the high-end model, and was developed.
TDA1541A which was rich in the linearity in Loule Bell with the high order accuracy is used for a D-A-conversion part, and the outstanding resolution has been obtained by adoption of the 4 time oversampling digital filter of the 16-bit excellent in a phase and the frequency characteristic.
Moreover, low-noise operational amplifier is used for a filter circuit.
The circuit board has adopted the computer-aided design and that including a digital analog converter have eliminated the signal failure, making full use of a surface mounting technology.
CDM-4M [ newly developed ] is carried in the mechanism part. The floating of the whole mechanism is carried out from a chassis, and it is intercepted from the oscillation. Moreover, the special resin of glass-fiber mixing is adopted as a laser pickup, and exact tracking is made possible, without being influenced by oscillation.
Honeycomb structure excellent in shock resistance is made the main chassis, and rigidity is secured by the newly developed triangle construction that supports all contacts by a three-position.
Moreover, metal material is used for a top plate or a bottom.
Even if a maximum of 126 kinds of special NetWare programs turn off the power (as five per sheet), FTS by which memory is carried out is carried.
The edit mode which can perform the edit united with the length of a special-NetWare-program play of 20 music or a tapes, and AMS (Automatic Music Scan) are carried.
In addition to a fixture and variable analog output, the digital output of light and a coaxial is carried.
MARANTZ CD-60
Disc format: CD
Digital converter: 16-bit, 4 x oversampling
Frequency response: 2Hz to 20kHz
Dynamic range: 96dB
Signal to Noise Ratio: 102dB
Channel separation: 100dB
Total harmonic distortion: 0.0015%
Digital outputs: coaxial, optical
Dimensions: 420 x 100 x 280mm
Weight: 4.9kg
Accessories: remote control
HiFiLab
Number of posts : 2838
