Audio Analogue Crescendo Integrated Amplifier (Made In Italy)
Item: Audio Analogue Crescendo Integrated Amplifier (Made In Italy)
Condition: 8.5/10. Item is in excellent condition. No dents or scratches
Price:RM2200 RM1900 or swap/topup
Click here to Whatsapp:
http://wasap.my/60123816611
[size=32]Crescendo Integrated Amplifier[/size]
The Crescendo Integrated Amplifier is the first amplifier in our catalog to enter Audio Analogue's world, characterized by a very high value for money and with absolutely amazing performances for the price range of the product, is definitely a reference for its category. The Crescendo Integrated Amplifier is in fact designed according philosophies "true high end" in all its parts. In designing Audio Analogue, as always, did not bet only to the electrical specifications, but we also worked mainly on sound and in collaboration with Airtech, the Crescendo integrated amplifier has further evolved: internal wiring made with 7N OCC copper, the same used for the prestigious AIRTECH cables, components of even higher quality and especially a few simple tweaks in the right places, yield a surprising musicality for equipment of this type. In addition to the sound performance improvements, it was designed a new aluminum front panel, always clean design and straightforward, but thicker and with exclusive workmanship.
Technical description
The Crescendo Integrated Amplifier has also been designed to be extremely versatile both in terms of inputs / outputs that feature, it is equipped in fact of 5 Line Inputs in the back panel and 1 Line Input on the front panel, REC OUT, headphone output on the front panel, the line input 5 can be configured to bypass mode allowing you to easily place the Crescendo Integrated Amplifier inside a AV system. In this configuration the Crescendo Integrated Amplifier can drive the front speakers, increasing the overall quality of system. The volume scale can be selected on the base of the sensitivity of the speakers, there are 4 different scales, three of which were designed for different sensitivities of the speakers and the fourth consists of 79 steps of 1dB each for a maximum scale precision. Balance function. Trigger-In input to be switched-on by a 12VDC trigger signal.
Technical features
Channels2Input impedance40KOhmPower on 8Ω load50W @ 0.05% THD + NPower on 4Ω load80W @ 0.05% THD + NLine Gain6dBPower Amp gain27dBFrequency Response(Att. 0dB, -3dB band)150 KHzInput Noise(Band limits 0Hz-80kHz/A-weighted)< -100 dBVSNR> 100 dBDimensions(HxWxD)81x445x390 mmWeight10.5 Kg
http://www.audioanalogue.com/en/crescendo-integrated-amplifier
https://6moons.com/audioreviews/audioanalogue/crescendo.html
http://www.hifi-review.com/150326-audio-analogue-crescendo.html
https://www.techradar.com/sg/reviews/audio-visual/hi-fi-and-audio/audio-systems/audio-analogue-crescendo-935712/review
Price:
Technical features
