Pioneer SP-C22 Center Speaker, by Andrew Jones
Designed by world-renowned speaker engineer Andrew Jones (lead designer for TAD-Labratories), these speakers embody all his high-end expertise and passion for pure audio reproduction.
Designed with uncompromising attention to detail, Pioneer SP-C22 speaker does the job in stunning fashion utilizing dual woofers in a full-sized cabinet for enhanced vocal performance.
True curved cabinet reduces standing sound waves, resulting in high performance and striking sound quality
2 x 4″ (100mm) Structured Surface Cone Woofer
1 x 25mm High Efficiency Soft-dome Tweeter
6 Element Sophisticated Crossover
90 Watt Power Handling
2-Way, Bass-reflex Type
RF Molded Curved Cabinet
Gold 5-Way Binding Posts
Frequency Response: 55Hz~20kHz
Sensitivity : 88dB
Impedance : 6ohms
Oversized Magnets with Vented Pole Piece for Improved Bass Response
Dimesion: W460 x H181 x D206 mm
Weight : 6.1kg
“This is the most affordable speaker in our lineup. It is a smart buy if you don’t want to spend much.”
“Surprisingly, for smaller woofers, these actually have low bass response. This center speaker has the ability to dip down to 55Hz, which put it among the best low-end performers we reviewed.”
” It has exceptional bass response and provides optimum value for a center speaker. If you are on a strict budget, you should consider this Pioneer speaker.”- http://center-speaker-review.toptenreviews.com/pioneer-review.html
The Pioneer SP-C22 speaker does the job in stunning fashion utilizing dual woofers in a full-sized cabinet for enhanced vocal performance.
Center Speaker Reviews and Buyer’s Guides
Comes with rubber holder, mesh grille. (No Box)
Great condition, perfect working.
RM300
Welcome for audition.
Subang Jaya ss14
Contact 012 6116917
https://www.facebook.com/Actsessory
