SOLD hase Linear 2000 Preamplifier
Item: Phase Linear 2000 Preamplifier
Condition: 8/10. Item is in excellent condition. No dents or scratches.
Price: SOLD or swap/topup
Click here to Whatsapp:
http://wasap.my/60123816611
https://stereonomono.blogspot.com/2012/10/phase-linear-model-2000.html
https://reverb.com/item/6362161-fully-restored-phase-linear-2000-stereo-preamp-with-ambience-output-for-quadraphonic-like-effects-great-platform-for-upgrades-mods
Item: Audio Analogue Crescendo Integrated Amplifier (Made In Italy)
Condition: 8.5/10. Item is in excellent condition. No dents or scratches
Price:RM2200 RM1900 or swap/topup
[size=32]Crescendo Integrated Amplifier[/size]
The Crescendo Integrated Amplifier is the first amplifier in our catalog to enter Audio Analogue's world, characterized by a very high value for money and with absolutely amazing performances for the price range of the product, is definitely a reference for its category. The Crescendo Integrated Amplifier is in fact designed according philosophies "true high end" in all its parts. In designing Audio Analogue, as always, did not bet only to the electrical specifications, but we also worked mainly on sound and in collaboration with Airtech, the Crescendo integrated amplifier has further evolved: internal wiring made with 7N OCC copper, the same used for the prestigious AIRTECH cables, components of even higher quality and especially a few simple tweaks in the right places, yield a surprising musicality for equipment of this type. In addition to the sound performance improvements, it was designed a new aluminum front panel, always clean design and straightforward, but thicker and with exclusive workmanship.
Technical description
The Crescendo Integrated Amplifier has also been designed to be extremely versatile both in terms of inputs / outputs that feature, it is equipped in fact of 5 Line Inputs in the back panel and 1 Line Input on the front panel, REC OUT, headphone output on the front panel, the line input 5 can be configured to bypass mode allowing you to easily place the Crescendo Integrated Amplifier inside a AV system. In this configuration the Crescendo Integrated Amplifier can drive the front speakers, increasing the overall quality of system. The volume scale can be selected on the base of the sensitivity of the speakers, there are 4 different scales, three of which were designed for different sensitivities of the speakers and the fourth consists of 79 steps of 1dB each for a maximum scale precision. Balance function. Trigger-In input to be switched-on by a 12VDC trigger signal.
Technical features
Channels2Input impedance40KOhmPower on 8Ω load50W @ 0.05% THD + NPower on 4Ω load80W @ 0.05% THD + NLine Gain6dBPower Amp gain27dBFrequency Response(Att. 0dB, -3dB band)150 KHzInput Noise(Band limits 0Hz-80kHz/A-weighted)< -100 dBVSNR> 100 dBDimensions(HxWxD)81x445x390 mmWeight10.5 Kg
http://www.audioanalogue.com/en/crescendo-integrated-amplifier
https://6moons.com/audioreviews/audioanalogue/crescendo.html
http://www.hifi-review.com/150326-audio-analogue-crescendo.html
https://www.techradar.com/sg/reviews/audio-visual/hi-fi-and-audio/audio-systems/audio-analogue-crescendo-935712/review
Item: Melos SHA-1 Tube Preamp/ Headphone Amplifier
Condition: 8.5/10. Item is in excellent condition. No dent or scratches. Comes with upgraded Nordost power cable installed.
Overview
The SHA-1 was a stunner of a preamp/headphone amp when it first came out. Back then, Melos Audio was one of the leading manufacturers for top class audio gears. They would give brands like Audio Research, Counterpoint, McIntosh, Conrad Johnson etc a good run for their money and in many cases, was the hands down best buy when you factor in their selling price. They were affordably priced, was solidly constructed, very well designed and engineered and more importantly, sounded like a high end component when their selling prices would have pointed otherwise. The SHA-1 was something of a dual purpose preamp where you can use it as a standalone headphone or as a three input preamp. Design was remarkably straightforward with a single focus on purity of sound which is evident on the front of the unit – toggle switches for turning on the unit and switching between the three inputs and a volume knob. Plain and simple. Output runs through a pair of 6922 tubes which gives it this warm textured but detailed sound. Tubes in there are currently Sovtek but feel free to tube roll on this unit to find a sound to your liking.
Price: RM2200 or swap/topup
Retail Price: RM4800
Melos SHA-1 Preamp/ Headphone Amp
Stereophile Recommended Components "Class A"
"...The first thing that struck me about the Melos's preamp performance was the utter clarity, the clear sense of ease throughout the entire frequency range...In short, the Melos KICKS ASS! It does nothing to alter the ambient soundfield in any way.. whatever soundstage depth is coming out of your source, the Melos will pass it along unscathed.I can't recommend the Melos SHA-1 highly enough. It's as good or better than any preamp I've heard at any price... the Melos SHA-1 is the only way to go; the closest thing yet to sticking your interconnects straight into your ears. Is it a Class A contender? I and I think so..." COREY GREENBERG - Stereophile
Review Link: http://www.stereophile.com/tubepreamps/617/index.html
Specifications:
Class-A hybrid tube/FET headphone amplifier/line stage.
Voltage gain: 19dB. THD: <0.07% at 1kHz, 1V output.
Polarity: non-inverting.
Frequency response: 15Hz-200kHz, +0, -1dB.
S/N ratio: 85dB ref. full output.
Input impedance: 100k ohms.
Output impedance (line): 0.5 ohms.
Maximum output (headphones): 3.5V.
Dimensions: 19" W by 17" D by 3.5" H. Weight: 12 lbs.
Outputs: 1 RCA, 2 Headphone Jacks
Inputs: 3 RCA
Type...........................................Class-A hybrid tube/FET headphone amplifier/line stage.
Voltage gain................................19dB.
THD............................................<0.07% at 1kHz, 1V output.
Polarity.......................................Non-inverting.
Frequency response....................15Hz to 200kHz, +0, -1dB.
S/N ratio.....................................85dB ref. full output.
Input impedance..........................100k ohms.
Output impedance........................0.5 ohms.(line)
Maximum output..........................3.5V.(headphones)
Weight........................................6 kg
Dimensions(w x d x h)..................48.5 x 37.5 x 10 cm
http://www.audioreview.com/product/amplification/preamplifiers/melos/sha-1.html
https://www.stereophile.com/headphones/617/index.html
https://www.usaudiomart.com/details/649470434-melos-sha1-rack-mountable-headphone-amplifier/
https://www.carousell.sg/p/melos-sha-1-tube-headphone-preamplifier-199365396/
https://www.ebay.com/itm/Melos-Audio-SHA-1-Stereo-Tube-Headphone-Amplifier-SHA1-Upgrades-/224085762046
PHASE LINEAR MODEL 2000
The Model 2000 Stereo pre-amplifier offers excellent specifications, outstanding sonic performance and a unique "Ambience Circuit" designed to retrieve out-of-phase signals while using the 2000 in a stereo mode. Prior to this time one had to add another amplifier and an additional set of speakers to utilize such a system, but this is not true of the ambience system in the 2000. When listening to a record played through the 2000 with the ambience circuit on, you will hear instruments that would not be audible on our preamps. The music is on the record out of phase and the 2000 corrects that problem
"In measurements made at CBS, the Model 2000 proved itself a strong performer. In neither channel did output clipping occur at less than 12,2 volts, whether driven singly or together. At an output level of 2 volts (more than enough for full output from most power amps), harmonic distortion was less than 0,02% in all cases - well below Phase Linear's 0,1% spec. And if we ignore as inaudible all harmonics above 20 kHz, harmonic distortion is no more than 0,0066%"
"The Model 2000 is as super in the listening as it is smooth in the handling. Once one has become used to the controls, they are convenient to operate and satisfying to touch. The extra flexibility in the tone controls (the separate knobs for each channel, as well as the variable turnover points) delivers worthwhile options."
Total Harmonic Distortion: Basically so low it is unmeasurable. Guaranteed less than 0,1% at rated output with 1 HF measurement.
Frequency Response: Phono ±0.5 dB of RIAA Standard
Input Sensitivity:
High level input : 40 K
Low level input : 47 K, 290 pf
Hum and Noise: 20 Hz - 20,000 Hz (inputs shorted)
High level : 88 dB belov 2 V
Low level : 74 dB a 10 mV input
Ambience Signal: (L-R) =L & (R-L)=R
Volume Control Tracking: Less than 1 dB Tracking error
Gain:
Low level (Phono) to pre-amp output : 56 dB at 1 kHz
Phono to Tape Output : 41 dB at 1 kHz
High Level to Pre-amp output : 15 dB at 1 kHz
Maximum Output Levels: Rated at 2 V : maximum 10 volts will source a 5 kohm load
Bass:
Turnover frequency 50 Hz : ±11 dB at 20 Hz
Turnover frequency 150 Hz : ±13 dB at 20 Hz
Treble:
Turnover frequency 5 kHz : ±10 dB at 20 kHz
Turnover frequency 2 kHz : ±14 dB at 20 kHz
Dimensions: 5½" (H) x 19" x 6" (D)
Weight: 15 lb
Price:
Technical features
Overview
Specifications:
Inputs: 3 RCA
Description :
The Melos SHA1 Class-A hybrid tube/FET headphone amplifier/line stage. It utilizes a specially selected 6DJ8 for nearly 20dB of gain, then follows it with discrete FETs to both buffer the tube and provide the current drive needed to properly drive dynamic headphones. The Melos SHA1 is also a line-level preamp with superb low-level dynamics, sweet yet crystal-clear highs, luscious mids and powerful lows.
Specifications :The Melos SHA1 Class-A hybrid tube/FET headphone amplifier/line stage. It utilizes a specially selected 6DJ8 for nearly 20dB of gain, then follows it with discrete FETs to both buffer the tube and provide the current drive needed to properly drive dynamic headphones. The Melos SHA1 is also a line-level preamp with superb low-level dynamics, sweet yet crystal-clear highs, luscious mids and powerful lows.
» Phase Linear 2000 pre amp (sold)
» Phase Linear 2000 Preamp (Rare Vintage) (SOLD)
» Counterpoint SA-2000 Tube Preamplifier (Used) SOLD
» Counterpoint SA-2000 Tube Hybrid Preamplifier (Used)
» Phase linear model 3300 series two preamplifier & model 300 series two power amplifier SOLD
