MS HD Power S20 V3 6 Way Filtered UK Mains Block
MS HD Power S20 V3 6 Way Filtered UK Mains Block Empty MS HD Power S20 V3 6 Way Filtered UK Mains Block
Post by raymond88 Tue Feb 16, 2021 10:15 pm
Item: MS HD Power S20 V3 6 Way Filtered UK Mains Block
Condition: 9/10. Item is in MINT condition. Still under warranty. With original receipt. Comes with original box.
Price: RM780 or swap/topup
Retail price: RM990
Click here to Whatsapp:
http://wasap.my/60123816611
MS HD Power S20 V3 6 Way Filtered UK Mains Block Mshd110
Overview
The MS Power HD S20 is a 6 way Filtered Mains Block, designed to accommodate all your hi-fi and AV equipment, offering PRRT noise filtration, as well as 48,000A surge suppression to protect all your hi-fi and AV equipment.
Finest Components
S20 V3 utilises 3.0µm pure 925 silver plating on all power clips as well as 5mm² power transmission bus bars with pure silver plating. The extension cord is double screened with the aim of this offering improved RF rejection.
The finest components and parts are used throughout the S20 to ensure that it performs to MS Power HD’s high standards.
Features
6 Ways BS-1363 13A Socket with Master ON/OFF Switch
PRRT Noise Filtration Network using Selected Components
Excellent EMI and RFI Suppression to Improve Audio and Visual Performance
48,000 Amp. Surge Suppression Protect Hi-Fi / AV Appliances
High Spring Rate Phosphor Bronze Sockets Clips
Passes the BS Standard 30,000 times plug IN / OUT test
3.0 µm Pure 925 Silver Plating to All Power Clips
5mm² Power Transmission Bus Bars with Pure Silver Plating for High Current Flow
Original 3 Cores 6N OFC Double Screened Extension Cord
Moulded-on Type Power Plug with 3.0 µm Pure 925 Silver Plated Pins
High Spring Rate Phosphor Bronze Fuse Clamps with 3.0 µm Pure 925 Silver Plating
Chassis Made of USA V-0 Grade Nonflammable Materials
Fitted with BS-1362 Standards 13A Fuse
MS HD Power S20 V3 6 Way Filtered UK Mains Block Mshd210
MS HD Power S20 V3 6 Way Filtered UK Mains Block Mshd310
Number of posts : 6945
MS HD Power S20 V3 6 Way Filtered UK Mains Block Empty Re: MS HD Power S20 V3 6 Way Filtered UK Mains Block
Post by raymond88 Fri Feb 26, 2021 12:48 pm
