Yaqin MS-650L 2A3 Push 845 Vacuum Tube Power & Integrated Amplifier
Product details of Yaqin MS-650L 2A3 Push 845 Vacuum Tube Power & Integrated Amplifier
- Amplifier output stage in a single-ended system with 2x26W (8ohm) power
- Triode mode in full class A
- Power amplifier based on 1 power triode 845 per channel
- Preamplifier based on 1 dual 6SN7 triode and 1 triode 2A3 power per channel
- Integrated power amplifier with preamplifier
- 4 RCA inputs
- 2 separate power outputs for 4 and 8 Ohm impedances
- Frequency range of the frequency response – 15Hz-30kHz
- Manual bias adjustment with built-in bias meter
- Two signal level indicators
- System that protects lamps when turning on the device
- Remote control – gain control and input selector
Specification parameters:
- Maximum output power: 26W x 2 (8Ω)
- Frequency response: 10Hz – 32KHz (NF)
- 10Hz – 22KHz (NO-F)
- Distortion: ≤1.3%
- SNR: ≥90dB
- Input sensitivity: Integrated Amps ≤280mV
- Pure Power Amps ≤2V
- The maximum power consumption: ≤550VA
- Load impedance: 4Ω~8Ω
- Power Tubes: PSVANE HIFI 845 x 2,
- Pre-Amp tubes: Russian 6H8c(6SN7) x 2, Chinese 2A3 x 2
- Machine size: 550 x 450 x 350 mm
- Packing size: 660 x 630 x 480 mm
- Input Power : 110v-240V 50/60hz
- Gross weight: 52kg
- Net weight: 45kg
18 months warranty
New in box
Price: RM14,999
yuenyan- Regular
- Number of posts : 92
