Yaqin MS-34B HIFI EL34 tube integrated push-pull HiFi Bluetooth amplifier
Yaqin MS-34B HIFI EL34 tube integrated push-pull HiFi Bluetooth amplifier Empty Yaqin MS-34B HIFI EL34 tube integrated push-pull HiFi Bluetooth amplifier
Post by yuenyan Tue Feb 23, 2021 2:18 pm
Yaqin MS-34B HIFI EL34 tube integrated push-pull HiFi Bluetooth amplifier Ms-35b12
Yaqin MS-34B HIFI EL34 tube integrated push-pull HiFi Bluetooth amplifier Yaqin-32
Yaqin MS-34B HIFI EL34 tube integrated push-pull HiFi Bluetooth amplifier Screen47
The main factors affect the sound quality of vacuum tube amplifier
1. Single-ended and push-pull circuit
At the end of the power amplification, amplification of push-pull is easier to get high power output, because push-pull is a vacuum tube amplifier "+" signal, a vacuum tube amplifier "-" signal, and then superimposed, so large distortion. Single-ended amplifier is a vacuum tube amplifier "+, -" signal, does not need the signal superposition, therefore less distortion. The sound Single-ended than push-pull good, especially in some minor details. However, Single-ended is difficult to obtain high power output, with vacuum tubes of the same type, Single-ended can do 10W, while push-pull is easy to do 30W, Single-ended to obtain large power will have to pay more price.
2. push-pull end power amplifier of vacuum tube different connections
push-pull the end of the power amplifying vacuum tube usually have three connections: triode form, super linear form and standard form. Theoretically speaking, the triode form by minimum distortion, output power is minimum; standard form get larger distortion, power is also the maximum; between super linear form between.
3. Affect the power transformer and output transformer of sound
High quality vacuum tube amplifier inseparable quality transformers, power transformers currently technically no trouble, the output transformer is the decision of the vacuum tube amplifier sound quality is the key. Because regardless of the output transformer selection is good, how sophisticated technology, both methods exist to avoid leakage inductance and stray capacitance components, resulting phase distortion. Output transformer as inductive element, to the transmission signals of different frequencies have different inductance. Therefore, the output of the transformer will be different in different voices lead. No high-quality output transformer, other aspects of the production of better quality vacuum tube amplifier is also meaningless.
18 months warranty
New in box
Price: RM5,299
yuenyan
Number of posts : 279
Yaqin MS-34B HIFI EL34 tube integrated push-pull HiFi Bluetooth amplifier Empty Re: Yaqin MS-34B HIFI EL34 tube integrated push-pull HiFi Bluetooth amplifier
Post by yuenyan Sat Mar 13, 2021 5:40 pm
yuenyan
Post by yuenyan Thu Apr 22, 2021 8:57 am
yuenyan
