Yaqin MS-845 Mono Block Power Amplifier (1pair)
Yaqin MS-845 Mono Block Power Amplifier (1pair) Empty Yaqin MS-845 Mono Block Power Amplifier (1pair)
Post by yuenyan Wed Feb 24, 2021 9:24 am
Yaqin MS-845 Mono Block Power Amplifier (1pair) Unname10
Yaqin MS-845 Mono Block Power Amplifier (1pair) Screen41
Yaqin MS-845 Mono Block Power Amplifier (1pair) Screen40
Features:
1.These a pair of Power amplifier is a low internal resistance of the power transistor (845), it is Class A single-ended amplifier, the sound quality is good.
2.Power amplifier drive circuit as “SRPP” circuit, and for the dual parallel, wide frequency response, pushing strong.
3.Japan imported the audio output transformer using dedicated oriented silicon steel Z11 (0.35mm thick) and oxygen-free high strength enameled wire and special winding process multi-group production, so that the machine wide frequency response, to ensure that the machine high, medium and low frequency sounds good , transparent and powerful.
4.This machine adopts foreign name Factory sound dedicated enthusiast and non-polarized electrolytic (MKP) Need for high-quality imported French Suren gold blocking capacitors and manufacturing, the main audio channel dedicated to use imported from Japan (ALPS) volume motor potentiometer, with quiet background music, low noise, no sound pollution and durable.
5.High-voltage power supply for the automatic delay control, can effectively extend the tube life.
Specifications:
Output Power: 25W + 25W (8Ω)
Distortion: ≤ 2.5% (1kHz)
Frequency response: 10Hz – 40kHz (-2dB)
SNR: ≥ 86dB (A)
Input Sensitivity: ≤ 0.2V
Load Impedance: 4Ω – 8Ω
Tube: after class: 12AU7 × 2 845 × 1
Power supply voltage: 110/220V 60Hz/50Hz
Volume: 315mm x 395mm x 435mm (D x W x H)
Gross Weight: 28kg x2 (a pair) = 56kg
18 months warranty
Conditions: New in box
Price: RM12,999
yuenyan
Number of posts : 509
Yaqin MS-845 Mono Block Power Amplifier (1pair) Empty Re: Yaqin MS-845 Mono Block Power Amplifier (1pair)
Post by yuenyan Thu Mar 18, 2021 4:29 pm
yuenyan
Post by yuenyan Wed Apr 21, 2021 4:29 pm
yuenyan
Post by yuenyan Sat Jul 03, 2021 11:36 am
yuenyan
Post by yuenyan Wed Sep 08, 2021 10:25 am
yuenyan
