YAQIN MC-13S Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier
YAQIN MC-13S Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier Empty YAQIN MC-13S Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier
Post by yuenyan Thu Feb 25, 2021 9:39 am
YAQIN MC-13S 6CA7-T Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier
YAQIN MC-13S Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier Y-mc-110
YAQIN MC-13S Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier Yaqin_10
YAQIN MC-13S Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier Y-mc-111
Features:
1.MC-13S is the latest upgraded version of MC-10L. It is powered by Yaqin 6CA7T tubes which are better than Shu Guang EL34B in sound quality;
2.An analog VU meter on the front panel to monitor the average of the two channel output levels;
3.Class A push-pull power amplifier to reduce distortion;
4.Ultra linear push-pull amplifier provides greater output power;
5.Output transformers manufactured with Japanese silicon steel sheet and high-quality enameled wire, which offer a wide dynamic range at full rated output;
6.Utilizes the audiophile capacitors and high quality metal precision resistors dedicated for audio frequency;
7.Beautiful heavy duty chassis (stainless steel top, steel bottom) and aluminum panel and bezels.
Parameters:
Tubes: EL34(6CA7)× 4 (Output Tubes)
12AT7 × 4 (Voltage amplifiers and drivers)
Maximum Output: 40W per channel (8Ω)
Output Jacks: Two channels with two groups gold plated jacks
Output Impedance: 4Ω and 8Ω
Input Sensitivity: 0.25V
Input Impedance: 20KΩ
Input Jacks: 4 Groups gold plated isolated RCA jacks (CD, DVD, Tape, and Tuner)
Distortion of Harmonic Wave: ≤0.9% (at 28W)
Frequency Response: 10Hz ~ 76KHz (-2dB)
Signal-to-Noise Ratio: >85dB (A weight)
Supply Voltage: AC 220V, 60Hz
Power Consumption: 220W
Net Weight: 18kg (40lb)
Shipping Weight: 23kg (47lb)
Shipping Dimension: 60 * 45 * 30 cm (24″ x 17″ x 12″)
18 months warranty
New in box
Price: RM2,999
yuenyan
Number of posts : 519
YAQIN MC-13S Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier Empty Re: YAQIN MC-13S Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier
Post by yuenyan Sat Mar 27, 2021 2:13 pm
yuenyan
Post by yuenyan Fri May 21, 2021 9:12 am
yuenyan
Post by yuenyan Wed Jul 28, 2021 8:39 am
yuenyan
Post by yuenyan Mon Oct 18, 2021 9:20 am
yuenyan
