Inakustik Reference BFA-103 Rhodium Coated Banana Plug
Inakustik Reference BFA-103 Rhodium Coated Banana Plug Empty Inakustik Reference BFA-103 Rhodium Coated Banana Plug
Post by yuenyan Sat Feb 27, 2021 10:17 am
Inakustik Reference BFA-103 Rhodium Coated Banana Plug 00789110
Inakustik Reference BFA-103 Rhodium Coated Banana Plug Csm_0020
Description
The best cable is the one that least affects the reproduction quality of the Hi-Fi or video chain and transmits the original signal with the minimum loss. And we have been fighting for this for over four decades. With products we have developed ourselves and our own cable manufacturing unit in which most cables from our Reference and Excellence quality levels are manufactured. Perfect performance instead of unnecessary losses. Physics instead of voodoo – that is our credo.
Reference Banana BFA-103
in-akustik has designed a connection for speaker cables using BFA bananas, which meets the strict requirements of the BFA standard (British Federation of Audio). The cable receptacle and the plug are constructed in one piece so that contact resistance can be avoided. The surface coating of rhodium is extremely durable. Suitable for in-akustik Reference speaker cables or all high end speaker cables with a diameter up to 10 mm².
New in box
Price: RM167
yuenyan
Number of posts : 527
Inakustik Reference BFA-103 Rhodium Coated Banana Plug Empty Re: Inakustik Reference BFA-103 Rhodium Coated Banana Plug
Post by yuenyan Tue Mar 16, 2021 3:52 am
yuenyan
Post by yuenyan Thu Apr 29, 2021 10:18 am
yuenyan
Post by yuenyan Thu Jul 08, 2021 5:11 am
yuenyan
Post by yuenyan Fri Sep 17, 2021 4:33 am
yuenyan
