Inakustik Reference CAT7 Network Cable (1.5 meter)
Inakustik Reference CAT7 Network Cable (1.5 meter) Empty Inakustik Reference CAT7 Network Cable (1.5 meter)
Post by yuenyan Mon Mar 08, 2021 11:07 am
Inakustik Reference CAT7 Network Cable (1.5 meter) 00715010
Inakustik Reference CAT7 Network Cable (1.5 meter) Csm_0078
Description:
The CAT7 Referenz cable is a LAN cable for high-end network connections. Because of the high production quality, it well surpasses the specifications required by EN50288-4-2 / IEC61156-6 (600 MHz), and reaches band widths of over 1200 MHz. This makes it equipped for high-speed networks with 10 Gbps (10 Giga bits per second). It was however, through exacting maintaining the impedance of its data lines, especially conceived for low-loss HD audio and HD video streaming. The PE-Network Jacket also prevents disturbing microvibrations, while the high-grade CAT Referenz plug rounds the product off.
  • Four twisted-pair data lines
  • Foamed PE lead insulation
  • Data pairs equipped with separate foil shielding
  • Common braided shield
  • PE-Network Jacket
  • Referenz metal plug
New in box
Price: RM1,139
yuenyan
Number of posts : 238
Inakustik Reference CAT7 Network Cable (1.5 meter) Empty Re: Inakustik Reference CAT7 Network Cable (1.5 meter)
Post by yuenyan Thu Apr 15, 2021 10:41 am
yuenyan
