Rythmik FV15HP Direct Servo subwoofer 15″ (Piano Gloss)
Rythmik FV15HP Direct Servo subwoofer 15″ ported audiophile subwoofer (Piano Gloss)
Description
FV15HP is our answer to the need for a high power home theater solution that retains the dynamic and accurate bass that we have become known for. We recommend this subwoofer for systems in which high-output home theater has a high priority.The FV15HP is our answer to the need for a high power home theater solution that retains the dynamic and accurate bass that we have become known for. Correctly integrated, our vented subwoofers can achieve the tight bass normally associated with a sealed enclosure, yet with greater low frequency output. We recommend this subwoofer for systems in which high-output home theater has a high priority or for use in very large rooms. It features Direct Servo:tm: to ensure accurate frequency and transient response, precise detail and extremely low distortion levels at even high output levels. As a discerning listener you appreciate that bass is the foundation of a satisfying music or home theater experience. You also appreciate that there is more to a home theater subwoofer than shaking the room, and that music can be far more satisfying with a subwoofer that can play deep.
What makes this subwoofer unique? It’s not that it can plumb the depths with authority. There are already many subwoofers on the market which can do that. The difference is that this subwoofer will reproduce bass with a level of realism that matches what our loudspeakers are known for…
We are most proud to represent these astonishing new subwoofers.
New in boxPrice: RM11,600
- Number of posts : 1404
» Rythmik FV15HP Direct Servo subwoofer 15″ – Piano Gloss
» Rythmik FV15HP Direct Servo subwoofer 15″ ported audiophile subwoofer
» Rythmik FV18 Direct Servo subwoofer 18″
» Rythmik Audio Direct Servo subwoofer
» Rythmik F12 Direct Servo Subwoofer
