Rythmik E15HP Diect Servo 15″ Subwoofer
Description
Spouse friendly compact sub;
E15 is our answer to the need for more output in a compact size. It is based on F15HP so it has more output than our standard subs, yet we have carefully reduced the size to minimise the visual impression of size without substantial sonic compromise. We’ve reduced the width by 2″ and the depth by 1″ while the height remains the same. So E15 can be considered the smaller spouse-friendly version of F15HP.;
There are other small but powerful subs on the market, but what E15 achieve is a smart mix of brute force, small size and finesse. Now the articulate and dynamic bass that our other subs have become known for is available with greater punch and smaller size.;
Direct Servo Technology;
All our subwoofers use our patented Direct Servo technology, providing high end performance at an affordable price. It allows us to use lighter and more efficient drivers and still achieve deep bass without using excessive amounts of power. The servo reduces memory effects, counteracts thermal compression and various forms of driver non linearities.
H600PEQ3 Amplifier and DS1510 Driver
E15 uses our new high power H600PEQ3 servo amplifier and DS1510 driver. DS1510 features anodized aluminum cone, a 3″ voice coil, and 200 oz magnet. Its linear excursion range has increased to +/- 20mm (from +/-15mm of DS1500). The entire subwoofer is 12lbs heavier than DS1501.Direct Servo technology
All our subwoofers feature our Direct Servo technology, which is our secret to achieving tight and accurate bass. The benefits are far more than simply achieving low distortion.;
15″ black anodized aluminum high excursion drive
DS1510 Driver features include:
- 3″ voice coil for high thermal power handling and low thermal compression
- Rigid black anodized aluminum cone ensuring control at high SPL
- Low moving mass to ensure an exceptional transient response
- High flux density in the gap to ensure low distortion
- Flux modulation shorting rings to lower inductance and improve linearity
Compared to our standard range of drivers, our DS1510 has a 3″ voice coil which has a high thermal power handling and features lower power compression. While designed primarily for their sound quality, these custom designed drivers are also stylish in appearance with a anodized aluminum cone and rubber surround. Unfortunately, it’s not possible to judge the accuracy of a driver by observing its appearance. There are other drivers on the market which in fact look quite similar, and it’s tempting to think that they are comparable. Many of them are inferior in performance due to a heavy moving mass, the absence of shorting rings, wider gaps around the voice coil and high inductance which limits the useable high frequency cut off point. Many aren’t suitable for a crossover point higher than 50 Hz. This is very limiting when one considers the large number of home theatre speakers which perform better when relieved of bass duties.
Quality enclosure
Our enclosures are very solid and well braced to minimize any cabinet resonances or coloration. The baffle into which the driver is mounted is double thickness.
We also provide a range of finishes.;
Bass extension controls
All of our subwoofers feature unique bass extension controls which are not normally provided on subwoofers. This enables the user to customize the output and extension to achieve the best compromise in any room. Most subwoofers neglect to provide bass extension control, and the result is that dynamic headroom is compromised.;
The bass extension controls enable the user to customize the frequency response of the low end. The controls customize a high pass filter, which attenuates frequencies below a given frequency. If set to 14 Hz, bass below this point will be filtered. The damping control determines the slope of roll-off and the amount of time domain ringing. High damping provides the least amount of time domain ringing and the most gradual roll-off curve. Low damping provides the steepest roll-off at the low end at the expense of added time domain ringing. The combination of 28hz and low damping is recommended for maximum SPL ouptut for all of our sealed subwoofers.Crossover options;
To suit different setups, we provide a 12 db and 24 db/octave crossover. If you are using an AVR, then we recommend “AVR/12” (or EXT/12 in older amps). If you are still using stereo receiver or conventional pre/power amp setup, then we recommend the 80hz/24 db/octave setting. To understand more about how to correctly integrate your subwoofer, read our;phase alignment;article.
Balanced professional version;
Shown above is XLR2 opton. Slave subwoofer units each have their own phase and PEQ adjustment, allowing for placement apart from each other. All other controls will use the same settings as the master sub. Therefore you can adjust the gain on the first and it will control the gain on all the others. The servo will still function normally, correcting any non linearities in each individual subwoofer. We also have XLR3 options with two XLR inputs and no XLR output.
PEQ parametric version
Our PEQ version comes with a few extra options which aren’t provided on our standard amplifier. First, there is one band of parametric EQ with adjustable frequency, gain and bandwidth. This means you can not only control the boost or cut, but also the width of the filter.
Additional bass management options are also provided. A switch allows the user to select a 12 or 24 db/octave crossover slope setup option. Where the higher slope (24db/octave) is selected, the amplifier uses a variable 12db/octave filter in addition to a fixed 12db/octave filter. One can choose with a switch the corner frequency of the fixed filter as either 50 or 80 Hz, which will suit most situations. The variable filter can be used for fine tuning.
New in box
Price: RM9,800
Whatsapp: Yuen Yan 010-3535484
- Number of posts : 1404
» Rythmik E15HP SE Diect Servo 15″ Subwoofer
» Rythmik E15HP Subwoofer (used)
» Rythmik Audio E15HP Subwoofer (sold )
» Rythmik FV15HP Direct Servo subwoofer 15″ ported audiophile subwoofer
» Rythmik F18 SE Direct Servo subwoofer 18″
