Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Empty Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp
Post by raymond88 Sun Mar 21, 2021 5:23 pm
Item: Rega Aria Switchable MM/MC Turntable Phono Stage
Condition: 9/10. Item is in MINT condition. Like buying new. Comes with original box.
Price: RM3500 or swap/topup
Retail Price: RM4,849.00
Click here to Whatsapp:
http://wasap.my/60123816611
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Regaar10
Overview
Housed within our latest half width custom designed case are two entirely separate, high performance phono stages. One fully adjustable, dedicated moving coil and one moving magnet. Each stage is designed and engineered to maximise the potential of your vinyl system whilst remaining easy to use and set up.
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Regaar11
Features
Technology
  • The Aria is an “all analogue amplifier” with no digital control circuitry. The fully aluminium case screens the internal circuit from any stray RFI signals. Our designers have avoided including any superfluous gadgets as they obstruct the signal path and degrade the sound quality. The Aria incorporates many innovative design ideas including a self-adjusting servo control to keep the MC input circuit at its optimum, compensating for any variations in ambient or operating temperature.
  • Both stages have their own separate input sockets and input pre-amplifier circuitry. This enabled us to design bespoke input circuitry for each cartridge type without compromise. Signal switching is performed at high level and low impedance (via relays) ensuring there is no degradation of the signal.
MC Stage Design & Features
  • The MC input uses parallel connected, low noise FET’s (Field Effect Transistor’s) configured as a compound pair. The use of FET transistors ensures there is no bias current flowing in the cartridge coil so as not to upset the delicate magnetic geometry of the cartridge. The MC input has the provision for selecting resistive input loading of 70ohms to 400ohms and capacitive loading of 1000pF to 4200pF. The input sensitivity can be changed by 6dB via the back panel.
MM Stage design & features
  • The MM input uses low noise, bipolar input transistors also configured as a compound pair. There are two separate power supplies for each channel and further sub-power supplies for each of the low noise input circuits. Nichicon FG electrolytic capacitors have been used in critical positions throughout the power supplies. Polypropylene capacitors have been used in the signal path and equalization networks. Discrete circuitry is used throughout the signal path ensuring full control of the circuit design.
    Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Regaar12
Aria MC dip switch settings for all Rega MC cartridge models
Specification
GENERAL
Maximum output level
11v RMS
Rated output level
200mV
Output resistance
100Ù
Minimum output resistance for a
–3dB point at 15Hz = 1K
AC supply 230v & 115v Nominal +/- 10%
Power Consumption
10 Watts
Ambient operating temperature 5 to 35°C
Dimensions W 220mm x D 320mm x H 80mm
115v 20mm Fuse T500mAL
230v 20mm Fuse T250mAL
Actual Item:
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Regaar13
https://www.cmy.com.my/shop-online/rega-aria-turntable-phono-stage/
Item: Pathos Acoustics In The Groove Mk2 MM/MC Phono Stage
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Dead quiet, musical, MM and MC, up to 80db of gain and balanced/XLR (as well as single ended/RCA but sounds better Balanced). Beautiful Italian build quality.
This state-of-the-art phono preamp utilises entirely independent left and right channel operation, powered by high-quality batteries in order to provide the cleanest, most stable power possible. The output from the pick- up on InTheGroove is low, so the risk of picking up unwanted sounds and resonances is higher. Using batteries ensures that the risk of potential interference from the power supply is minimalised, the power is phenomenally stable.
Price: RM3900 or swap/topup
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Pathos22
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Pathos23
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Pathos24
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Pathos25
Pathos Acoustics In The Groove mkII phonostage
It has taken the excellent Pathos engineers many resources to develop a phono preamplifier superior to the original and highly appreciated InTheGroove. The very refined sound follows the Pathos tradition of great soundstage, high realism, transparency, dynamics and musicality.
The InTheGroove MKII is a state of the art phono-amplifier that features completely independent left and right channel operation. Powered by batteries in order to provide as clean and stable power as possible. Since the output from the pick-up is low, the risk of disturbing the signal is higher. By using batteries in the power supply the risk of interference is minimised  the power is extremely stable and thereby avoids the turbulence that often appears on the mains net.
Another elaboration to ensure high sound quality is taken by using selected components of highest quality and balanced mode operation. Balanced layout is something rarely seen in phono amplifiers  but it has the advantages of lower noise and therefore a cleaner signal. The input-stage is the most critical in a phono-amplifier. The first gain stage is an ultra-low noise circuit to boost the weak signal from the cartridge. InTheGroove MkII uses JFETs to ensure the lowest possible input random noise. After the JFET input stage the very finest opamps handles the signal and ensures the correct gain. Together these initiatives ensure high gain, low noise and a peerless sound.
Gain is user selectable with an additional 20dB. The built in charger makes it easy to use and set-up. After a period with no signal it will switch off automatically and recharge if the batteries are low. This guarantees the longest life of the batteries. The variety of adjustments gives you a very user-friendly high-end phonostage  so you can get your cartridge to perform the best. The Pathos engineers have done their best to assure that you get the full value of your vinyl collection.
Main Specifications:
Type: passive RIAA in pure Class A powered by batteries.
Input state by low noise transistors
Balanced output
Gain 60dB + possibility of adding another 20dB.
Charger built in, automatic stand-by.
Frequency response: 10Hz-100 KHz
S/N ration: 80dB @1KHz/5cm/s
Input impedance: MM 47KOhm/47pF MC 100Ohm/1nF
Item: NAD C545BEE Cd Player
Price: RM1380  or swap/topup
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Nad111
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Nad211
Item: Marantz PM17 KI Phono Integrated Amplifier (by Ken Ishiwata)
Condition: 8/10. Item is in excellent condition. No scratches or dents. Highly sought after K.I Signature version in copper casing.
 Yet another masterpiece from the mind of Ken Ishiwata. The copper-plated chassis and rear panel reduce signal-degrading electromagnetic interference, while its rigid die-cast chassis and solid aluminium case virtually illiminate mechanical vibration. 60W per channel @ 8ohms, very refined and beautiful sounding.
Price: RM3300 or swap/topup
https://sg.carousell.com/p/marantz-pm17-ki-integrated-amplifier-reduced-204032553/
https://www.ebay.com.hk/itm/Marantz-PM-17-KI-Signature-Integrated-Amplifier-mint-in-black-w-remote-/321976496733
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp M312
SPECIFICATIONS
Power Output (8/4 Ohm RMS)60/100 Watts
Power Output (8/4 Ohm DIN)72/115 Watts
Power Output (8/4 Ohm IHF)75/125 Watts
Frequency Response5Hz-70kHz (+0,-1dB)
Total Harmonic Distortion0.01%
Bridged Power Output(8 Ohm RMS) -
Damping Factor100
Input Sensitivity:MM 2.5mV / 22kOhm
Input Sensitivity:MC 230ìV/100Ohm
Input Sensitivity:High level 220mV /22kOhm
Signal to Noise Ratio MM/MC/High Level  90/76/112 dB
Channel Separation:1kHz / 10kHz >74/>66 d
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp M112
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp M212
http://www.audioreview.com/product/amplification/integrated-amplifiers/marantz/pm-17-ki-signature.html
http://www.audiocostruzioni.com/r_s/ampli/amplificatori/marantz-pm17-kis/marantz-pm17-kis.htm
https://www.ebay.com/c/1323122024
Number of posts : 8684
Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp Empty Re: Rega Aria Phono, Pathos In The Groove Phono, NAD C545BEE CD, Marantz PM17 KI Amp
Post by raymond88 Sun Mar 28, 2021 8:47 pm
Post by raymond88 Sun Apr 04, 2021 7:15 pm
Post by raymond88 Wed Apr 14, 2021 2:07 pm
Post by raymond88 Fri Apr 23, 2021 1:26 pm
Post by raymond88 Fri Apr 30, 2021 7:14 pm
