Meridian MCD(used)
Meridian MCD(used)
Meridian MCD
High quality compact disc player / CD player from Philips 101(clone)
Cult player from the 80s,solid and hell-built solid to last .
Technical condition: The device is fully functional. Sometimes the CD stops after few tracks. sometime it is showing you her temper, what you need is be patient with her, finally she rewards you closer to LP aliked sound ,but without inherit any weaknesses of LP playback system .
The MCD player impresses with its excellent workmanship. heavily modified/upgraded by meridian genius to an extend No any CD100/101 in the world can sleep together in same bed . The tracking time is so much faster than 1st Gen. Don't be fool , it has ceramic 1540D which are proven to be more "concentrate" vocal accents than "plastic" type player, No any 1541s be it dual crown or triple crown could trounce it in term of "vocal" perspective.
cosmetic condition: The device is run hot (like most class A amp-fear) optically in a used condition with normal signs of wear / scratches ,the paint is serious flaked due to high- heat get toasted ,black coating (Nextel) is worn by aging exposed to heaty case. ,what u want is sounds. No appearances!
This is a Grandma Player, and everlasting sound quality rival any modern pis of equipment for musicality & Reliability ,finally your hearing wont get damaged.
All for asking Rm2999.50
flyfly- Frequent Contributor
- Number of posts : 168
Registration date : 2009-09-30
Re: Meridian MCD(used)
commercially available stand alone CD players from around 1984, and its certainly built like a tank! Its just ludicrously heavy and over engineered. Even the CDM1 chasis appears to be one solid lump of metal
I've tried a few CD's/Chinese black CD/CDRs in it, and it seems to be happy to play whatever i've thrown at it.
