Elac BS403
Elac BS403  Empty Elac BS403
Post by mike67 Sat Apr 03, 2021 9:55 am
Elac BS403  Elac_410
Elac BS403  Elac_411
 In small to medium-sized rooms, this 2-way, bass-reflex design delivers extraordinary sound that will leave even the most critical listeners enthralled. Made in Germany.
Speaker type: 2-way, bass reflex
Tweeter: 1 x JET 5
Woofer: 1 x 150 mm AS -XR cone
Crossover frequency: 2,500 Hz
Frequency response: 41 to 50,000 Hz
Sensitivity: 86 dB at 2.83 v/1m
Recommended amplifier power: 40 to 200 Watt / channel
Nominal/peak power handling: 70 / 100 Watt / channel
Nominal impedance: 4 Ω; minimum 3.2 Ω @ 260 Hz
Binding posts: 5-way metal
Magnetic shielding: No
Cabinet finishes: High gloss black, white or walnut veneer; oiled walnut
Accessories included: Magnetic fabric grille
Height: 12.1" / 308 mm
Width: 6.5" / 166 mm
Depth: 10.9" / 277 mm
Net weight (each): 16.1 lb / 7.3 kg
RM9000 / WhatsApp mike 0168606677 Washington Audio
mike67
Number of posts : 798
Registration date : 2009-07-07
http://www.washingtonaudio.com.my
