Unison Research, Unico Power Amplifier and Primo CD player set
Selling off both Unison Research, Unico Power Amplifier and Primo CD player (comes with remote control). Not separating the set, whatsapp me if interested!
PLEASE READ THE DESCRIPTION, BEFORE COMMENTING ANYTHING. PRICE WILL BE STATED HERE. PERSONALLY WHATSAPP ME IF INTERESTED IN BUYING OR YOU HAVE ANY QUESTIONS. BRIEF DESCRIPTION OF BOTH ITEMS WILL BE WRITTEN HERE.
Unico Power Amplifier, comes with built in phonostage. Specs:
Unico Primo CD player (with remote control) specs:
Condition: 9/10
Selling Price: RM 6800 for both (Negotiable)
Whatsapp: +60164221082/+60124278800
(Click Images to View Full Picture)
- Output power: >80W RMS on 8Ω
- Output stage: Dynamic A Class POWER MOSFET complementary pair
- Polarization: Classe A Dinamic
- Input stage: Triodi A-Class A
- Valve: 1 x ECC83 (12AX7)
- Sensibilty: 260mV
- Input impedance: 50 kΩ / 47 pF
- Frequency response: -0.1dB@10Hz / -0.5dB@100kHz
- SNR: 90dB
- THD: 0.15% @ 10W, 1kHz
- Negative feedback: 10dB
- Damping Factor: >50
- Inputs: 5 line RCA, 1 tape RCA
- Output: 1 tape RCA, 1 subwoofer RCA
- Output connectors: 4 +4 per Bi-Wiring
- Remote control: Volume, IR
- Power consumption: 380W max
- Dimensions (la x lu x alt): 43.5 x 43 x 9.5 cm
- Net weight: 14 kg
- Transport: TEAC CD5010A
- Digital interface: Wolfson Micro WM8804
- Sample Rate Converter: Burr Brown SRC4192
- Convertiter D/A: Wolfson Micro WM8524
- Sampling: 24bit / 96kHz
- Digital Standard: AES3, IEC60958 (S/PDIF) e EIAJ CP-1201
- Digital input (Ext): Isochronous-Out 16bit / 32-48kHz (USB-B)
- Digital output: 44.1kHz
- Output stage: solid state, Class A
- Outputs: 1 RCA
- Gain: Triode Class-A
- Valve: 1 x ECC82 (12AU7)
- Power conumption: 100W max
- Net weight: 10 kg
Condition: 9/10
cliffwong90- Frequent Contributor
- Number of posts : 211
