Audio Analogue Maestro Settanta REV 2.0 Integrated Amplifier (Used)
Audio Analogue Maestro Settanta REV 2.0 Integrated Amplifier (Used) Empty Audio Analogue Maestro Settanta REV 2.0 Integrated Amplifier (Used)
Post by choyaudiovisual Wed Apr 07, 2021 5:28 am
Audio Analogue Maestro Settanta REV 2.0 Integrated Amplifier (Used) Img_1725Audio Analogue Maestro Settanta REV 2.0 Integrated Amplifier (Used) Img_1726Audio Analogue Maestro Settanta REV 2.0 Integrated Amplifier (Used) Img_1727Audio Analogue Maestro Settanta REV 2.0 Integrated Amplifier (Used) Img_1728
Technical description
Toroidal transformer analogical power supply with two separated lines, one for each channel Analogic circuits with separated components, large pass band and low counter-reaction. Highest-quality passive components; lowest-tolerance metallic-layered resisters (MIL standard); low-tolerance, non-polarized polyester/propylene capacitors; high-speed, low-loss, high-capacity electrolytic capacitors; organic-electrolyte, low-capacity electrolytic capacitors. Integrated-resistance network volume controls with no buffer for maximum sound transparency. Advance micro-controlled protections for amplifier and speaker preservation with low impact on sound quality. Multiple source system control: front panel, IR remote control, RS- 232 interface. Microcontroller system control High-contrast PLED dot-matrix display. High-resolution selector encoder.
Technical features
Power 70W into 8ohms/140W into 4ohms
Inputs  5 x unbalanced line (one can be optimised for MM/MC phono)
Outputs Pre out, tape out
Dimensions (HxWxD) 135 x 445 x 410mm
Weight  18kg
https://www.audioanalogue.com/en/maestro-settanta/maestro-settanta-rev20-integrated-amplifier
*NO REMOTE!!Conditions: 8/10 (USED)
Price: RM6900 inclusive postage to West Malaysia
Whatsapp: Choy 012-5685484
Number of posts : 2816
