Sonus Faber Venere 2.0 Bookshelf Speaker with Original Speaker Stand (Used)
Sonus Faber Venere 2.0 Bookshelf Speaker with Original Speaker Stand (Used) Empty Sonus Faber Venere 2.0 Bookshelf Speaker with Original Speaker Stand (Used)
Post by choyaudiovisual Wed Apr 07, 2021 10:55 am
Sonus Faber Venere 2.0 Bookshelf Speaker with Original Speaker Stand (Used) Img_1813Sonus Faber Venere 2.0 Bookshelf Speaker with Original Speaker Stand (Used) Img_1812Sonus Faber Venere 2.0 Bookshelf Speaker with Original Speaker Stand (Used) Img_1811
The Venere 2.0 is the largest stand mount/bookshelf loudspeaker in the Venere family and like the other models, it shares the same Lyre cabinet shape that exhibits great structural rigidity and has no parallel walls. This sophisticated enclosure features both sculpted sides to avoid diffraction of sound and a tilted baffle board providing time alignment for the drive units.
By using a front reflex port, the Venere 2.0 avoids the negative rear wall interference often found in rear ported designs, making it easier to get great sound in virtually any room. The two drive units are of Sonus faber design, and the 2.0 employs a fabric dome tweeter along with a 7″ mid-woofer that results in great speed, detail, and control. The thoughtfully designed crossover network ensures a low distortion signal path and musicality across the critical crossover point of 2,500 Hz. When compared to the Model 1.5, the 2.0 will deliver greater dynamics, lower frequency extension and a weightier tonal quality.\
System:2-way bookshelf / floor stand vented box
Tweeter:1” (29 mm) High-definition fabric dome
Mid-Woofer:7″ (180 mm) Curv cone driver
Crossover Point:2.5kHz
Frequency Response:45Hz – 25kHz
Sensitivity:88 dB SPL (2.83 V/1m)
Nominal impendence:6 ohms
Suggested Amplifier Power Output:50W – 200W without clipping
Dimensions (HWD)17.7 x 9.7 x 13.3 in., 449 x 246 x 336 mm
Optional Dedicated Stands:27.5 x 10.9 x 12.9 in., 698 x 276 x 326 mm
Dimensions:44.5 x 10.9 x 15.4 in., 1130 x 276 x 391 mm
Weight:15.5lbs., 7.0kg each
*WITHOUT JUMPER!!
Conditions: 9/10 (USED)
Price: RM4800 inclusive postage to West Malaysia
Whatsapp: Choy 012-5685484
Number of posts : 2821
