Furutech LAN-10G ethernet network cable(NEW)
Furutech LAN-10G ethernet network cable(NEW) Empty Furutech LAN-10G ethernet network cable(NEW)
Post by YUAN Thu Apr 29, 2021 12:13 pm
Furutech LAN-10G Ethernet Network Cable
What do you want from a network cable?
You want it to meet or exceed all specifications, using the best materials construction and superior high-conductivity connectors as possible for long life, long-run capability.
The Cat-6 LAN-10G network cables are constructed using the same Pure Transmission principles found in Furutech’s highest specification audio cables; improve every element and connection in the signal path to create a maximally-optimized, low-noise pathway for signal to travel.
For reliable, beautifully engineered and manufactured LAN requirements you just can’t do better than Furutech LAN 10-G cables!
FEATURES
・The Furutech LAN 10G Network cable handles frequencies up to 500MHz
・Supports 10Gbps applications up to 100-meters maximum
・Main conductor wire: 24 AWG silver-plated α (Alpha) OCC conductor for minimal transmission loss
・RJ45 Connector: α (Alpha) nonmagnetic 24k gold-plated conductor with 24k Gold-plated weak-magnetic copper alloy body
・Superior dual-layer isolation: AL foil and copper wire braiding
SPECIFICATIONS
・Jacket: UL/C-UL/CSA-approved flammability-rated CMR-grade, RoHS-compliant flexible PVC (Dark Blue), OD: 6.5mm approx.
・Production Lengths: 1.2M
Condition: NEW
Price: RM500.00
For more details call or whatapps:
Yang 018-9742567
Yuan 016-5368723
Furutech LAN-10G ethernet network cable(NEW) Img_2066
Furutech LAN-10G ethernet network cable(NEW) Img_2065
YUAN
Number of posts : 16
