DACs: TEAC, Audiolab, Audio Research DAC9, Cambridge Audio, etc
Item: Audio Research DAC 9 Tube DAC
Condition: Item is like new. Just taken out to take picture and testing.
Selling: RM26k or swap/topup
Retail Price: RM39,000
TRADE IN ACCEPTED
Click here to Whatsapp:
http://wasap.my/60123816611
The DAC9 digital-to-analog converter decodes most current formats with state-of-the-art vacuum tube technology. Five digital connections – USB, RCA, BNC, AES/EBU, and Toslink – provide connectivity to all of your digital sources. Quad DAC architecture provides a balanced digital signal, wide dynamic range, and decoding resolutions from red book CD up to 384 kHz and native DSD sampling rates. A pair of 6H30 vacuum tubes are the heart of the analog circuit. Both balanced and single-ended connectors are provided for output connectivity.
https://audioresearch.com/product/dac-9/
[url=https://www.absolutesounds.com/pdf/main/press/HFN_Audio Research DAC9_lowres.pdf][url=https://www.absolutesounds.com/pdf/main/press/HFN_Audio Research DAC9_lowres.pdf[/url]]https://www.absolutesounds.com/pdf/main/press/HFN_Audio%20Research%20DAC9_lowres.pdf[/url][/url]
https://www.soundstageultra.com/index.php/equipment-menu/722-audio-research-foundation-dac9-digital-to-analog-converter
https://hometheaterhifi.com/reviews/dac/audio-research-dac-9-tube-dac-review/
https://www.paragonsns.com/products/audio-research-dac9
https://www.tonepublications.com/review/the-audio-research-dac-9/
Item: Audiolab Q-DAC Digital To Analogue Converter
Condition: 8.5/10. Item is in excellent condition. No dents or scratches.
Price: RM1100 or swap/topup
Retail Price: RM1999
http://www.hifi-review.com/152671-audiolab-q-dac.html
https://www.audiovisualonline.co.uk/product/7720/audiolab-q-dac-silver-digital-to-analogue-converter/
Item: Cambridge Audio DACMagic Upsampling DAC
Condition: 8.5/10. Item is in excellent working condition. No dents or scratches. Comes with power cable.
Price: RM750 or swap/topup
TRADE IN ACCEPTED
DESCRIPTION
FREQUENCY RESPONSE
+/-0.15dB 20Hz – 20kHz; +/-3.0dB 6Hz – 192kHz.
THD+NOISE
Less than .002% at 2V RMS 1kHz Balanced output.
SIGNAL TO NOISE
>114dB.
IMD + NOISE
.001% (SMPTE ratio)
CHANNEL SEPARATION
107dB.
INTRINSIC JITTER
<10pS.
DAC RESOLUTION
24 bits.
PUSH BUTTONS
Power, Menu, Option, Enter, Input, Mute.
OUTPUT IMPEDANCE
500 Ohms balanced, 250 Ohms SE.
DIGITAL FILTER
Selectable Fast or Slow algorithms.
UPSAMPLING
All Inputs upsample to 384kHz.
INPUTS
USB2.0HS 44.1 to 384kHz, DSD, 2xDSD; RCA, BNC, XLR 44.1 to 192kHz; TOS 44.1 to 96kHz.
RATED OUTPUTS
3.8V RMS Max Balanced; 1.9V max SE (@ 0dB input).
POWER SUPPLIES
Electronically-regulated low and high voltage supplies. Line regulation better than .01%.
NOISE
-103dB
TUBE COMPLEMENT
(2) 6H30 dual triodes.
POWER REQUIREMENTS
100-125VAC 60Hz (200 – 250VAC 50/60Hz) 60 watts maximum.
STAND BY
Less than 2 watt.
DIMENSIONS
Width: 19″ (48 cm)
Height: 7″ (17.8 cm)
Depth: 15.5″ (39.4 cm)
Handles extend 1.50″ (3.8 cm) forward of the front panel.
Weight: 32.0 lbs. (14.6 kg) Net; 43.2 lbs. (19.8 kg) Shipping.
THD+NOISE
SIGNAL TO NOISE
>114dB.
IMD + NOISE
.001% (SMPTE ratio)
CHANNEL SEPARATION
107dB.
INTRINSIC JITTER
<10pS.
DAC RESOLUTION
24 bits.
PUSH BUTTONS
OUTPUT IMPEDANCE
DIGITAL FILTER
UPSAMPLING
INPUTS
RATED OUTPUTS
POWER SUPPLIES
NOISE
-103dB
TUBE COMPLEMENT
POWER REQUIREMENTS
STAND BY
Less than 2 watt.
DIMENSIONS
Width: 19″ (48 cm)
Audiolab Q-DAC Features
Automatic detection decoding of external digital input sources
ESS 9016 Sabre DAC chip, 8 Channel 32bit processor
Digital optical and coaxial S/PDIF inputs as well as USB
A fully asynchronous interface coupled to a minimum jitter Master Clock system
High contrast LED display
Audiolab custom filters
» DACs: Wadia, Goldmund Stellavox, Audiolab Q-DAC
» SOLD Cambridge Audio Topaz AM10 Integrated Amplifier and Cambridge Audio SX-60 Bookshelf Speakers.
» Audiolab, KEF, Sherwood, TEAC, interconnects & cables (used).
» Mark Levinson / Audio Research / Cary audio / Abbingdon Music Research (used)
» Cambridge Audio Integrated Amplifier Azur 351A and Cambridge Audio CD Player Azur 351C (USED)(SOLD)
