NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Empty NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc
Post by raymond88 Mon May 03, 2021 1:06 am
Item: Pioneer BDP-450 Blu-ray/SACD player
Condition: 8.5/10. Item is in excellent condition. Comes with original remote and power cable.
Price: RM750 or swap/topup
Click here to Whatsapp:
http://wasap.my/60123816611
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Pionee15
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Pionee16
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Pionee17
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Pionee18
Item: NAD CD Player C565 BEE
Condition: 8.5/10. Item is in excellent condition. Comes with original remote control and power cord.
Price: RM1450 or swap/topup
Retail Price: RM2999
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Nad113
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Nad213
NAD CD Player C565BEE is the top of the line in NAD's Classic Series range.
It has performance that is very close to our vaunted Masters Series M5 CD Player.
Features:
-  Play CD, CDR/RW
-  USB input
-  Optical input
-  Optical and Coaxial outputs
-  Wolfson 24/192 DACs
-  Toroidal power transformer
-  Original remote control
Item: Denon PMA-360 Integrated Amplifier
Condition: Item is in very good working condition. No dents or scratches. Item is very well kept and in a very clean condition.
Price: RM650
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Denonp18
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Denonp19
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Denonp20
https://www.carousell.com.my/p/denon-pma-360-integrated-amplifier-1081364460/
Specifications :
  -   1990 vintage
 -   Speakers : A, B, A + B  front switching
-   Power rating x 2 : 60W RMS at 8 ohms,   90W at 4 ohms
 -   Total harmonic distortion : 0.008%
-   Record preamp output : 150mV
-   Input sensitivity / impedance : line: 150mV / 47kohms,  MM: 2.5mV / 47kohms,  MC: 0.2mV / 100ohms
 -   Phono : RIAA ± 0.3dB [20Hz to 20kHz],  input overload [1kHz]: MM: 160mV,  MC: 12mV
-   Signal to noise ratio : Phono: MM: 94dB [5mV input],  MC: 75dB [0.5mV input],  CD / tuner / Aux / tape 1, 2: 107dB
-   Source Direct : for tone controls bypass
-   Tone controls : Bass: ± 8dB at 100Hz,  Treble: ± 8dB at 10kHz,  loudness: +7dB at 100Hz, +6dB at 10kHz
-   Phono : MM moving magnet and MC moving coil options  rear switching
-   Dimensions [W x H x D] : 434 x 120 x 279mm
-   Weight : 5.8kg  - packed 7.5kg
Item: Oppo HA-1 Headphone Amplifier, DAC & Pre-Amplifier
Condition: 8.5/10. Item is in EXCELLENT condition. Looks like new. Comes with original remote control.
Stereo Pre-Amplifier with Home Theater Bypass
Discrete Class A Balanced Headphone Amplifier, Asynchronous USB DAC Up to 384 kHz and DSD256, Stereo Pre-Amplifier with Home Theater Bypass.
The HA-1 doubles as a high fidelity stereo pre-amplifier with both RCA and XLR output ports. A special "Home Theater Bypass" mode can be assigned to any input source, making it very easy to integrate the HA-1 as a stereo pre-amplifier into a home theater sound system.
Price: RM3800 RM3500 or swap/topup
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Oppo110
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Oppo210
HIGH PERFORMANCE AUDIO
Discrete Class A Amplifier
  • A Class A amplifier conducts signal over the entire range of the input signal cycle. The output transistors are biased to operate in their most linear range, and there is no crossover distortion caused by switching the signal between two push-pull devices. The HA-1’s power amplification circuit for the headphones is Class A built with discrete transistors. The discrete design allows us to hand-pick and match the best parts to build the HA-1.
Toroidal Power Supply
  • A toroidal power transformer offers superior power efficiency and much lower exterior magnetic fields over traditional laminated steel core transformers. The HA-1’s toroidal linear power supply provides a very clean and robust power source to the audio components.
Fully Balanced Design
  • The internal analog audio signal path of the HA-1 is fully balanced. For digital audio, the signal runs in balanced mode all the way from the DAC to the output jacks. Balanced analog input is kept intact, and single-ended input is converted to balanced at the input buffer. All single-ended outputs are derived from the balanced signal as well. The balanced design provides better common-mode noise rejection and improves signal quality. The balanced headphone output provides twice the voltage and four times the power of the single-ended output, enabling the HA-1 to drive the most power hungry headphones. It also provides better channel seperation by eliminating the common ground return path.
ESS Sabre32 Reference DAC
  • The DAC is one of the most important components for digital audio playback. The SABRE32 Reference ES9018 from ESS Technology is the world’s best performing 32-bit audio DAC solution targeted for high-end consumer applications and professional studio equipment. With the ESS patented 32-bit HyperstreamNAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   2122.png?v=2.2 DAC architecture and Time Domain Jitter Eliminator, the SABRE32 Reference DAC delivers an unprecedented DNR (Dynamic Range) of up to 135dB and THD+N (Total Harmonic Distortion plus Noise) of -120dB, the industry’s highest performance level that will satisfy even the most demanding audio enthusiast. To learn more about the technologies behind the exceptional performance of the SABRE DAC, please read the SABRE Technical White Paper.
Clean Signal Path
  • The HA-1 uses an analog potentiometer (the familar volume knob) to control the volume. By avoiding re-digitizing the audio signal for volume adjustment, the HA-1 provides a clean signal path for the audio. At the same time, the convenience of modern digital volume control is not lost – a remote-controlled motor turns the volume knob and a 10-bit analog-to-digital converter samples the signal to display a numeric dB level.
Made for iPodNAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   00ae.png?v=2.2, iPhoneNAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   00ae.png?v=2.2 and iPadNAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   00ae.png?v=2.2
  • The HA-1 passes Apple’s “MFi” certification and is compatibile with the latest iPod, iPhone and iPad to be used as the digital audio output accessory of these devices. By tapping directly into the digital audio signal of these devices and converting the audio to analog using the high performance SABRE32 Reference DAC, music from your favorite portable device will sound its best.
Wireless Audio via Bluetooth
  • The HA-1 supports Bluetooth Advanced Audio Distribution Profile (A2DP) with both the standard and aptXNAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   00ae.png?v=2.2 high quality codec. Simply pair your phone with the HA-1 and set music free wirelessly from your mobile phone.
  • By bypassing the low fidelity, poor quality DAC of traditional computer soundcards, the HA-1 turns any computer into a high performance multi-media source by converting digital audio to analog through the ESS Sabre32 Reference DAC. The asynchronous transfer mode uses the high precision clock inside the HA-1 to drive the audio signal, not relying on the clock quality of the computer. HA-1’s USB DAC input supports PCM up to 384 kHz 24-bit and DSD up to 12 MHz (DSD256).
Adjustable Gain Setting
  • The headphone power amplifier has an adjustable gain setting. For optimal sound quality and to best match your headphones’ sensitivity, you can choose between Normal and High for the Headphone Gain setting.
Build Quality
  • The HA-1 is housed in a brushed aluminum chassis. The Class A amplifier naturally consumes more power and generate more heat than other types of amplifiers, so the HA-1 is designed with ample ventilation and built with the finest components to ensure long term stability and performance. Tipping the scale at 13 lbs, the HA-1 is a solidly built desktop headphone amplifier.
  • The HA-1 doubles as a high fidelity stereo pre-amplifier with both RCA and XLR output ports. A special “Home Theater Bypass” mode can be assigned to any input source, making it very easy to integrate the HA-1 as a stereo pre-amplifier into a home theater sound system.
Trigger Input & Output
  • The HA-1 features 12V trigger input and output. When used as a stereo pre-amplifier, the trigger output can turn on your power amplifiers automatically when the HA-1 is turned on. You can also turn on the HA-1 automatically by connecting its trigger input to the trigger output of a source device or a surround sound processor.
Remote Control & App
  • The HA-1 comes with a remote control that provides volume control, direct source selection and even playback control for digital audio sources. A remote control app is available for both Apple’s iPhone and Android-based smartphones. The app works over Bluetooth and offers the same functionality as the physical remote control.
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Oppo410
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Oppo510
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Oppo610
Item: ProAc Studio 110 Bookshelf Speakers
Condition: 8.5/10. Item is in excellent condition. No dents or scratches.
Price: RM3500 RM3300 or swap/topup
Brand Name :Proac
Product Line:Studio
Manufacturer Part Number:STUDIO 110
Technical Information :
Minimum Frequency Response: 33 Hz
Sensitivity: 88 dB
RMS Output Power: 15w-150 W
Impedance: 8 Ohm
Maximum Frequency Response: 30 kHz
Driver Type:
165.10 mm Woofer, 25.40 mm Silk Dome Tweeter
Physical Characteristics :Stand Mountable
Weight Approximate: 9 kg
Colour : Cherry
Dimensions:380 mm (H): 203 mm (W): 240 mm (D)
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Proac110
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Proac510
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Proac210
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Proac310
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Proac410
Number of posts : 7112
NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc   Empty Re: NAD CD Player C565 BEE, Pioneer BDP-450 Blu-ray/SACD player,Denon PMA-360 Integrated Amplifier, etc
Post by raymond88 Sun May 09, 2021 11:44 pm
