(USED) Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC
(USED) Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC Empty (USED) Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC
Post by JEFFCHAM168 Wed Jun 02, 2021 2:17 am
Item: Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC
Condition: 8.5/10. Item is in excellent condition. No dents or scratches.( Used Less than 6 Month )
Price: RM2950
Reason For Sales : Upgrade to SACD
Contact: 019-7533638-JEFF
Click here to Whatsapp:
http://wasap.my/60197533638
(USED) Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC Whatsa13
(USED) Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC Whatsa14
(USED) Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC Whatsa15(USED) Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC Whatsa22
(USED) Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC Whatsa23
(USED) Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC Whatsa24
https://hifi-exquis.com/banlanced-cd-player/543-meixing-mingda-mc500-cd-balanced-12au7-tube-cd-player.html
Technical Parameters:
· Upswing: 2x and 4x
· Frequency response: 20Hz~20kHz±0.5dB
· Dynamic Range: Greater than 100dB
· Signal to noise ratio: greater than 110dB (A weighting)
· Channel separation: greater than 98dB (1kHz)
· Total harmonic distortion: <0.05%
· Output level: 2.3V ± 3dB
· Voltage: 110v-120v or 220v-240v
· Power consumption: ≤60W
· Size: 430 ×100 ×330 mm
· Weight: 13KG
· Package Included:1 × Finished electronic tube audio player
Features:
· With USB input interface.
· The servo circuit uses the SAA7824 chip.
· Use the CS4398 D/A converter.
· Use the OPA2604 as a high-quality filter circuit to completely filter out digital signals and restore pure music signals.
· The United States RUBY brand (12AU7 × 2) analog amplifier circuit.
· Use ERSE capacitors for tube coupling.
· 8 sets of independent regulated power supply, less mutual interference, strong driving force, rich music details.
· With a group of coaxial digital signal output, RCA and smooth audio signal output each group.
· Use the power input LC filter circuit to clean the power supply and make the music background clearer.
· The countdown is 20 seconds after the start-up, so that the electronic tube is warmed up before entering the working state.
· 1.2mm thick aluminum chassis and metal movement, strong seismic performance, make the sound more clean.
· Excellent frequency up processing to increase the 44.1kHz sampling frequency of CD-disc signals to 88.2kHz or 176.4kHz.
JEFFCHAM168
Number of posts : 6
Registration date : 2021-01-16
JEFFCHAM168 likes this post
(USED) Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC Empty Re: (USED) Cube MC500-CD Balanced With Ruby 12AU7 Tube CD Player USB DAC
Post by JEFFCHAM168 Tue Jun 15, 2021 9:41 am
JEFFCHAM168
Number of posts : 6
Post by JEFFCHAM168 Thu Jul 01, 2021 6:52 am
UP,,,
JEFFCHAM168
Number of posts : 6
