B.M.C Audio PureDAC1 dac pre-amplifier(SOLD)
B.M.C Audio PureDAC1 dac pre-amplifier(SOLD) Empty B.M.C Audio PureDAC1 dac pre-amplifier(SOLD)
Post by YUAN Wed Jun 30, 2021 9:05 pm
Features:
  • Top-grade Digital/Analog Converter with Current Injection current-to-voltage (I/V) conversion
  • High-resolution asynchronous USB interface up to 24bit/384kHz
  • USB PCM: 16...32bit; 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384kHz.
  • USB DSD: DSD64, DSD128.
  • ASIO driver for Windows; Linux and Mac compatible
  • AES/EBU, coaxial and Toslink digital inputs
  • Balanced, reference-class headphone amplifier with digital/analog power convertion (DAPC), load-effect free (LEF) technology, a lateral MOSFET, a super-low impedance LEF output stage, and lossless Digital Intelligent Gain Management (DIGM) volume control
  • Balanced LEF, CI-compatible preamp that optionally operates in B.M.C. Mode, with DIGM and a vertically diffused metal oxide semiconductor (DMOS) and LEF-balanced output stage.
  • Separate volume controls for the line and headphone sections (the line volume position 59 represents a DAC standard output level)
  • Second-generation DIGM with optimized gain distribution between power amps and internal and DIGM volume levels
  • Optical B.M.C. Link for connecting with B.M.C. amps like the PureMono
  • Remote Control
  • Massive and stylish extruded aluminum chassis
  • Dimensions: 14.37 x 4.06 x 12.91 inches, W/H/D (365 x 103 x 328 mm)
  • Weight: 11.9 lbs (5.4 kg)
   CONDITION:8/10
   PRICE: RM4000(NEGO)
   FOR MORE DETAILS PLS CALL OR WHATAPPS:
   018-9742567 YANG
   016-5368723 YUAN
B.M.C Audio PureDAC1 dac pre-amplifier(SOLD) Img_2081
B.M.C Audio PureDAC1 dac pre-amplifier(SOLD) Img_2080
YUAN
Number of posts : 22
