Audio Note AN-J/B Speakers
 Audio Note AN-J/B Speakers Empty Audio Note AN-J/B Speakers
Post by raymond88 Wed Jun 30, 2021 11:27 pm
Item: Audio Note AN-J/B Speakers
Condition: 8/10. Item is in very good working condition.
Price: RM4600 or swap/topup
Can Trade-In your Speakers/ CD Player/
Amplfier/Etc
 Audio Note AN-J/B Speakers Audion16
 Audio Note AN-J/B Speakers Audion18
 Audio Note AN-J/B Speakers Audion17
 Audio Note AN-J/B Speakers Audion19
 Audio Note AN-J/B Speakers Audion20
Description :
The Audio Note AN-J/B is a 6 ohms two way speaker based on an early Peter Snell design: wide front, narrow front-to-back, and fairly large for a "bookshelf" speaker. It undergoes the painstaking driver selection and matching process, which ensures the closest tolerances within a pair in the entire audio industry. The Audio Note AN-J/B is a ported enclosure with an efficiency better than 93dB/m and bass that goes down to 25Hz at -6dB. The materials used for drivers are good, old fashioned paper for the woofer cone and impregnated silk for the dome tweeter. These materials, when matched correctly, marry the low and high frequencies seamlessly, providing the best level of performance possible in the real world of acoustics. Bracing and internal damping is kept to a minimum and strategically applied to help, not hinder the drivers.
The Audio Note AN-J/B has been designed to be placed close to room boundaries, where the bass performance is augmented significantly by the additional reinforcement offered by the nearby walls. In this position, it will outperform any similarly sized speaker regardless of origin, thanks in part to the shallow cabinet and wide baffle shape which gives the drivers the best possible operating conditions, allowing them to perform as if they are mounted in a virtual wall. This provides the most undisturbed sound field with the widest and most even dispersion possible from a real world cabinet shape. The crossover of the Audio Note AN-J/B is simple, essentially first order, hardwired and incorporates air-cored chokes and selected bipolar and polypropylene capacitors.
The sound is immediate and dynamic with very natural tonality and remarkable bass extension for its size. The bass is also deep and tuneful with incredible microdynamics. The midrange is expertly textured and expressive without being overly lush and natural. The treble is smooth and accurate without any taint of harshness. The Audio Note AN-J/B is capable of reproducing the scale and intensity of most well-recorded music very realistically. The sheer musicality gives a huge improvement in soundstage width and depth, musical textures and clarity, even in a non-optimum setup. It performs extraordinarily well with any musical genre from simple acoustic to large scale orchestral music without getting muddled or compressed. It reproduces acoustic instruments and vocals extremely well, no sibilance and done with proper tonality. The Audio Note AN-J/B is a true joy to listen to, presenting the performance in a natural way, with great instrumental overtones and decent soundstage depth. All the octaves are well integrated, without noticeable discontinuities. The speakers are very coherent and the drivers blend wonderfully to speak with an unified voice, as if they are specially designed and built from the ground up to achieve this coherency. They are similar to a good single driver speaker but with much better bass and fullness.
The Audio Note AN-J/B's strengths lead to their main disadvantage. Their ability to present such a great musical performance on well recorded and produced music really shows the deficiencies of poorly done recordings. The compression, lack of soundstage and distortions on poorly produced examples are made all the more apparent. They do not accentuate their weakness, but it is not hidden. In terms of placement, Audio Note AN-J/B are very well suited for low-power tube amplifiers and can also be a good match for solid state amplifiers. It is a rear ported design that likes to be used very close to a rear wall and even across the rooms corners. They are ideally suited for rooms ranging from 130 sq. ft. to 430 sq. ft.
Specifications :
Characteristic Impedance..................6 ohms
Sensitivity........................................93dB for 1 watt at 1 meter
Frequency Response........................25Hz to 23kHz, +/- 6dB in room
Minimum Amplifier Power..................7 watts RMS per channel
Maximum Amplifier Power.................150 watts(unclipped) RMS per channel peak
Driver Complement...........................20.3cm paper cone, foam surround bass driver
                           ............................2.5cm silk dome tweeter
Dimensions(w x d x h)......................33 x 25.5 x 59 cm
Weight............................................14kg
http://www.listeninn.com/product/407001-11456/Loudspeaker/Audio+Note+AN-J/B
Number of posts : 7470
 Audio Note AN-J/B Speakers Empty Re: Audio Note AN-J/B Speakers
Post by raymond88 Wed Jul 07, 2021 6:05 pm
Post by raymond88 Wed Jul 14, 2021 6:32 pm
All my other items for sale:
CD Player:
Bluesound Node 2i (New)
DAC:
Phono Stage:
Pathos Acoustics In The Groove Mk2 MM/MC Phono Stage @ RM3300
AV Processors/Receiver:
Denon AVC-X8500H Receiver @ RM15,900
Pioneer LX-88 Receiver @ RM3650
Pre Amplifier:
Herron Audio VTSP-1 Tube Preamp @ RM7500
Bryston BP17 Preamplifier @ RM7800
Melos SHA-1 Tube Preamp/ Headphone Amplifier @ RM2200
Musical Fidelity M1 CLiC Universal Music Controller / Network Player /Streamer/ Pre-Amplifier @ RM3100
Conrad Johnson Premier 16LS
Music Reference RM-5 Mk4 Tube Preamplfier @ RM4500
Power Amplifier:
Music Reference RM-10 Power Amplifier @ RM7800
Rogue Audio Magnum M-120 Monoblock Power Amplifier @ RM8500
Naim NAP-155xs Power Amplifier @ RM4200
Naim NAPSC Power Supply @ RM1500
Sanders Magtech Stereo Power Amplifier @ RM12,800
Integrated Amplifier:
Devialet D200 Integrated Amplifier
MONA A1 Class A KT120 Tube Single-Ended Integrated Amplifier With Bluetooth 5.0 @ RM2,100
Thiel CS3.6 Floorstanding Speakers @ RM7500
Rogers LS66 Bookshelf Speakers @ RM1500
Dynaudio Contour S5.4 Floorstand Speakers
Odeon Audio Orfeo Bookshelf Speakers
Spendor Classic 200 Speakers
PSB Imagine X2T Tower Loudspeakers @ RM5500
Dynaudio Audience 72 SE Floor Standing Speakers @ RM3000
Speaker Stand:
Guizu Solid Teak Wood Speaker Stand with Cast-iron Base and Spikes @ RM1000
Custom-made 6-Columns Audiophile Bookshelf Speakers Stands @ RM1600
Speaker Cables:
XLO Ultra 12 Bi-wire Speaker Cable - 6 feet pair @ RM1500
Xindak FS-1 Speaker Cable - 2.5m @ RM1200
Subwoofers:
JL Audio Dominion D-110 10"Inch Powered Subwoofer - 750W (Black Ash) (NEW) @ RM5500
MBWS Audio  MS-12 USA Subwoofer @ RM4999
Orisun USA SUB-1230 Active Sub 12" @ RM1999
Interconnects:
Van Den Hul The Second XLR Interconnect - 0.8m @ RM730
FURUTECH FireBird-96 ( 9pin-6pin ) IEEE1394 Fire Wire Cable 0.6m @ RM450
Cardas Audio Lightning 15 75 ohm SPDIF Coaxial Digital Cable - 1.5m @ RM1350
Power Cables:
Aural Symphonics 20A Missing Link Cubed Power Cable @ RM1900
Tice Power Cord Model "Power Conductor 2"- 2.5m @ RM1500
Furutech NanoFlux Power Cord - 1.8m @ RM8500
Vitus Andromeda Power Cord - 1.5m @ RM3600
Power Conditioner:
Torus IS Toroidal Isolation Power Transformers @ RM8300
Others:
JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit @ RM1290
Solid Tech Feet Of Silence (Set of 4) NEW @ RM1500
Subwoofer Base Vibration Isolation Platform @ RM690
Graham Slee - Solo Ultra-Linear Headphone Amplifier + PSU1 Power Supply @ RM1800
CAN VIEW THE DETAILS HERE:
Post by raymond88 Tue Jul 27, 2021 10:27 pm
