WTS David Hafler Preamp 110 and Power Amp 220
WTS David Hafler Preamp 110 and Power Amp 220 Empty WTS David Hafler Preamp 110 and Power Amp 220
Post by Zen|th Thu Jul 01, 2021 12:33 pm
Preloved
1) Hafler Power amp 220 for sale (RM1200)
- the on/off button seem to be loose so u might need to change it. It will always be ON once u power it up from the main power supply. U can a replacement switch for very cheap at any electronic store ~rm5-10. I didn’t
bother to get it because this is rarely used
- US version so u need a step down transformer
Specs:
Power output: 115 watts per channel into 8Ω (stereo)
Frequency response: 6Hz to 60kHz
Total harmonic distortion: 0.02%
Damping factor: 60
Input sensitivity: 1.55V
Signal to noise ratio: 100dB
Semiconductors: 26 x transistors, 8 x MOSfet, 29 x diodes, 4 x zener diodes, 1 x diode bridge
Dimensions: 5-1/8 x 16 x 10-1/2 inches
Weight: 26lbs
2) Hafler Pre amp 110 - RM1100
- US version
- Condition 7/10 (mainly cosmetic)
- the direct out left channel has a dry joint so need to adjust the cable for the best signal. If not, u can just do a minor resolder
Get both power and pre for RM2000
More pictures are on Facebook
WTS David Hafler Preamp 110 and Power Amp 220 Img_3714
WTS David Hafler Preamp 110 and Power Amp 220 Img_3715
Location SS2 - COD only
0102257529
Zen|th
Number of posts : 4
Registration date : 2020-11-18
