Roger Modjeski's Music Reference RM-10 Stereo Tube Power Amplifier
Item: Roger Modjeski's Music Reference RM-10 Stereo Tube Power Amplifier
Price:RM7300 RM6900 or swap/topup
Click here to Whatsapp:
http://wasap.my/60123816611
Reviewer: Tom Lyle
Price:
Reviewer: Tom Lyle
Re: Roger Modjeski's Music Reference RM-10 Stereo Tube Power Amplifier
All my other items for sale:
CD Player:
Bluesound Node (New)
DAC:
Phono Stage:
AV Processors/Receiver:
Denon AVC-X8500H Receiver @ RM15,900
Pioneer LX-88 Receiver @ RM3650
Pre Amplifier:
Herron Audio VTSP-1 Tube Preamp @ RM7500
Bryston BP17 Preamplifier @ RM7800
Melos SHA-1 Tube Preamp/ Headphone Amplifier @ RM2200
Musical Fidelity M1 CLiC Universal Music Controller / Network Player /Streamer/ Pre-Amplifier @ RM3100
Conrad Johnson Premier 16LS
Music Reference RM-5 Mk4 Tube Preamplfier @ RM4000
Jeff Rowland Capri S1 Preamplifier w Phono @ RM6300
Power Amplifier:
Music Reference RM-10 Power Amplifier @ RM7800
Rogue Audio Magnum M-120 Monoblock Power Amplifier @ RM8500
Naim NAP-155xs Power Amplifier @ RM4200
Naim NAPSC Power Supply @ RM1500
Sanders Magtech Stereo Power Amplifier @ RM12,800
XTZ Edge A2-300 Power Amplifier @ RM2300
Integrated Amplifier:
Devialet D200 Integrated Amplifier @ RM20k
MONA A1 Class A KT120 Tube Single-Ended Integrated Amplifier With Bluetooth 5.0 @ RM2,100
SPEC Corporation RSA-M3EX Integrated Amplifier @ RM29k
Rogue Audio Pharaoh Tube Hybrid Integrated Amplifier @ RM7500
Thiel CS3.6 Floorstanding Speakers @ RM7500
Rogers LS66 Bookshelf Speakers @ RM1500
Dynaudio Contour S5.4 Floorstand Speakers
Odeon Audio Orfeo Bookshelf Speakers
Spendor Classic 200 Speakers
PSB Imagine X2T Tower Loudspeakers @ RM5500
Dynaudio Contour S1.4 Bookshelf Speakers @ RM6800
Speaker Stand:
Guizu Solid Teak Wood Speaker Stand with Cast-iron Base and Spikes @ RM1000
Custom-made 6-Columns Audiophile Bookshelf Speakers Stands @ RM1600
Speaker Cables:
XLO Ultra 12 Bi-wire Speaker Cable - 6 feet pair @ RM1500
Xindak FS-1 Speaker Cable - 2.5m @ RM1200
Cardas Clear Light Speaker Cables - 2m pair @ RM2500
Cardas Clear Speaker Cables - 2.5m pair @ RM4500
XLO Ultra 6 Speaker Cables - 6 feet pair @ RM900
Subwoofers:
JL Audio Dominion D-110 10"Inch Powered Subwoofer - 750W (Black Ash) (NEW) @ RM5500
MBWS Audio MS-12 USA Subwoofer @ RM4999
Orisun USA SUB-1230 Active Sub 12" @ RM1999
Interconnects:
Van Den Hul The Second XLR Interconnect - 0.8m @ RM730
FURUTECH FireBird-96 ( 9pin-6pin ) IEEE1394 Fire Wire Cable 0.6m @ RM450
Cardas Audio Lightning 15 75 ohm SPDIF Coaxial Digital Cable - 1.5m @ RM1350
Power Cables:
Aural Symphonics 20A Missing Link Cubed Power Cable @ RM1900
Tice Power Cord Model "Power Conductor 2"- 2.5m @ RM1500
Furutech NanoFlux Power Cord - 1.8m @ RM8500
Vitus Andromeda Power Cord - 1.5m @ RM3600
ASI Liveline Power Cable - 1.8m @ RM2700
Power Conditioner:
Torus IS Toroidal Isolation Power Transformers @ RM8300
Others:
JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit @ RM1290
Solid Tech Feet Of Silence (Set of 4) NEW @ RM1500
Subwoofer Base Vibration Isolation Platform @ RM690
Graham Slee - Solo Ultra-Linear Headphone Amplifier + PSU1 Power Supply @ RM1800
CAN VIEW THE DETAILS HERE:
CD Player:
DAC:
Phono Stage:
Pre Amplifier:
Power Amplifier:
Speaker Stand:
Speaker Cables:
Subwoofers:
Interconnects:
Power Cables:
Power Conditioner:
Others:
» Roger Modjeski's Music Reference RM-10 Stereo Tube Power Amplifier
