Celestion SL600si speakers(used)
Celestion SL600si speakers(used) Empty Celestion SL600si speakers(used)
Post by joe79 Tue Aug 17, 2021 11:46 pm
Celestion SL600si speakers(used) 20210894
Celestion SL600si speakers(used) 20210895
Celestion SL600si speakers(used) 20210896Celestion SL600si speakers(used) 20210898
Celestion SL600si speakers(used) 20210897
Celestion SL600si speakers(used) 20210899Celestion SL600si speakers(used) 20210101
Celestion SL600si speakers(used) 20210100
Celestion SL600si
Model : SL600si
Speaker Jumper will be giving as well,speaker jumper cable using transparent cable to make.
Condition : 7/10
Price : rm3200
Contact : 0146206422 pj
Sidebar 5: Specifications Celestion SL600Si: two-way, sealed-box loudspeaker with Aerolam (aluminum-honeycomb) enclosure. Drive-units: 1.25" copper-dome tweeter, 6.5" Kobex-cone (PVC) woofer. Crossover frequency: 2.3kHz, second-order, 12dB/octave slopes. Frequency response: 60Hz-20kHz ±3dB, low-end, -6dB at 60Hz in free-space conditions. Sensitivity: 82dB/W/m. Nominal impedance: 8 ohms. Amplifier requirements: up to 120W on program.
Dimensions: 14.5" (368mm) H by 7.75" (197mm) W by 9.25" (235mm) D. Enclosure volume: 12 litres (0.4 cubic feet). Weight: 11.25 lbs (5.1kg) each.
Miscellaneous :
Made In...........................................UK, England
joe79
Number of posts : 322
Registration date : 2010-04-06
Celestion SL600si speakers(used) Empty Re: Celestion SL600si speakers(used)
Post by joe79 Wed Sep 01, 2021 2:16 am
joe79
Post by joe79 Sat Sep 18, 2021 10:06 pm
Up
joe79
