Rel Storm III 10" Subwoofer (USED)
Rel Storm III 10" Subwoofer (USED) Empty Rel Storm III 10" Subwoofer (USED)
Post by YUAN Fri Sep 03, 2021 5:12 pm
REL Acoustics Storm III 10" Subwoofer System 150watt RMS, 300 Peak w/ Manual & Cables Black
This very technically tuned subwoofer offers great functionality for many different stereo/surround setups. Dial in the mode, Rolloff, and hertz and this sub will perform beautifully for you. Fully tested and 100% functional; we were very impressed at the range of this subwoofer. The sale will included the manual, REL Storm III literature, power and Speakon cables.
  • True 150W (continuous) discrete direct-coupled MOSFET amplifier
  • Downward-firing 250mm long-throw driver with heavy-duty cast chassis
  • Ultra-rigid 30mm cabinet
  • Improved ABC® filtering circuit with 24 musically correct semi-tone increments between 22Hz-96Hz.
  • Four position mode selector: line/LFE (0 degrees phase and 180 degrees phase)
  • Audiophile grade toroidal transformer
  • Gas-tight Neutrik high level connection for long-term consistency of sound quality
  • High guality, panel-mounted twin phono inputs at OdB and +12dB (low level)
  • High and low level balanced inputs (Neutrik/XLR)
  • Totally discrete input circuitry for high and low level inputs
  • Separate volume controls for high and low-level input adjustment
  • Simultaneous connection of high and low level sources
  • Set-Safe® audibly transparent driver protection
  • Double-sided glass-fibre board with plated-through holes
  • IEC power input socket - non-captive lead for installation flexibility
  • Hand-built in Great Britain
CONDITION : 8/10
PRICE : RM4000(NEGO)
FOR MORE DETAILS PLEASE CALL OR WHATAPPS:
018-9742567 YANG
016-5368723 YUAN
Rel Storm III 10" Subwoofer (USED) Img_2098
Rel Storm III 10" Subwoofer (USED) Img_2099
Rel Storm III 10" Subwoofer (USED) Img_2100
Rel Storm III 10" Subwoofer (USED) Img_2101
YUAN
Club Member
Club Member
Number of posts : 27
