Denon PMA-800NE Integrated Amplifier & DCD-800NE CD Player
Denon PMA-800NE Integrated Amplifier & DCD-800NE CD Player Empty Denon PMA-800NE Integrated Amplifier & DCD-800NE CD Player
Post by stylelaser.com.my Tue Sep 28, 2021 9:26 pm
Denon PMA-800NE Integrated Amplifier & DCD-800NE CD Player Brand New. Now Selling At RM6,499. Free Shipping Within West Malaysia.
               Denon PMA-800NE Integrated Amplifier & DCD-800NE CD Player Es_de139
PMA-800NE
          Denon PMA-800NE Integrated Amplifier & DCD-800NE CD Player Es_de141          Denon PMA-800NE Integrated Amplifier & DCD-800NE CD Player Es_de140
Featuring digital inputs and a built-in phono equalizer, the Denon PMA-800NE integrated amplifier sets new heights in premium audio performance.
具有數位輸入和內置的唱頭等化器,Denon PMA-800NE綜合擴大機在高級的音訊性能中建立新高度。
Overview
The Denon PMA-800NE integrated amplifier sets new heights in premium audio performance with digital inputs and a built-in phono equalizer. From deep bass to detailed highs, listen to your favorite high-resolution audio content with the 192kHz/24bit D/A converter. At 85W (4 Ohms) per channel, the PMA-800NE supplies enough power to drive your speakers for optimal sound. Connect the PMA-800NE to your favorite components with the three Optical and one Coaxial digital inputs. Powered by the Denon Advanced High Current (AHC) single push-pull circuit power amplifier, the PMA-800NE provides exceptional sound quality that balances high power with delicate, musical details.
概述
Denon PMA-800NE綜合擴大機具有數位輸入和內置唱頭等化器,在高級的音訊性能中建立新高度。使用192kHz/24bit D/A轉換器聆聽您最喜愛的高解析音訊內容。每聲道85W(4 Ohms),PMA-800NE提供足夠功率驅動您的喇叭以達到最佳聲音。透過3個光纖和1個同軸數位輸入,將PMA-800NE連接到您喜愛的單機。由Denon高級大電流(AHC)單端推挽電路功率擴大機驅動,PMA-800NE提供出色的音質,使高功率與精巧的音樂細節達成平衡。
Features
  • 2 x 85 W (4 ohm) power output: Get the maximum performance to drive your favorite loudspeakers
  • Advanced High Current (AHC) Single Push-Pull circuit power amplifier: Wide bandwidth captures everything from deep bass to detailed highs
  • 3 Optical, 1 Coaxial digital input: Supports all digital music sources
  • Built-in 192kHz/24bit D/A converter: Experience high-resolution audio playback
  • Impeccable sound engineering with carefully selected and rigorously tested Hi-Fi parts: Enjoy the exceptional sound that is the signature of Denon amplifiers
  • Analog Mode for pure audio reproduction: Enjoy the richness of your treasured analog music sources
  • High performance MM and MC phono equalizer amp: Connect any turntable and enjoy vinyl tracks
  • Vibration-resistant design with Direct Mechanical Ground Construction: Listen to music with pristine detail and quality unaffected by the environment
  • Main transformer with separate coiled wires for audio/control circuits: Eliminates interference to optimize sound quality
  • Micro-processor with Stop Mode: Protects audio signal from external noise during playback
  • Denon-proprietary Signal Level Divided Construction (SLDC) chassis: Amplify and transmit delicate musical signals to the speakers to capture the nuance of the music
  • Engineered with a more than 100-year Denon legacy in audio excellence: Trust this high-quality and durable system to deliver the ultimate audio experience
  • 2 x 85 W (4 ohm)功率輸出:以最大的性能驅動您最喜愛的喇叭
  • 高級大電流(AHC)單端推挽電路功率擴大機:寬廣的頻寬捕捉所有從重低音到高音細節
  • 3個光纖、1個同軸數位輸入:支援所有數位音樂來源
  • 內置的192kHz/24bit D/A轉換器:體驗高解析音訊播放
  • 無可挑剔的聲音工程和精心挑選並經過嚴格測試的Hi-Fi零件:享受Denon擴大機出色的聲音
  • 類比模式提供純音訊重現:享受您珍貴的類比音樂的豐富來源
  • 高性能MM和MC唱頭等化擴大器:連接任何的唱盤,享受黑膠唱片音軌
  • 具有直接機械接地結構防震設計:聆聽音樂最原始的細節和不受環境影響的品質
  • 音訊/控制電路的主變壓器,獨立繞線:消除干擾以優化音質
  • 微處理器具有停止模式:播放時保護音訊信號免於外部噪音干擾
  • Denon專屬的信號級分立式結構(SLDC)底盤:擴大和傳遞精緻的音樂信號到喇叭,捕捉音樂的細微差別
  • 秉承Denon百年多來在音響領域的卓越傳奇:這款高品質耐用系統能帶來終極的音訊體驗
Denon DCD-800NE
          Denon PMA-800NE Integrated Amplifier & DCD-800NE CD Player Es_de142          Denon PMA-800NE Integrated Amplifier & DCD-800NE CD Player Es_de143
Features
  • USB DAC operation mode
  • Separated rectifier circuit for analog and digital circuitry
  • Display dimmer and off options
  • CD program, repeat, and random play modes
  • Auto power off
Enjoy stereo sound from a variety of CD types with the Denon DCD-800NE CD Player. It uses a Burr Brown PCM1795 digital-to-analog converter for detailed audio reproduction from the stereo RCA analog output, and also features an optical and digital coaxial output. The DCD-800NE will play CDs, CD-R/RWs, and MP3, WMA, and AAC files from CDs and USB drives.
Advanced AL32 Processing Plus
This analog waveform reproduction technology utilizes data interpolation algorithms, which support high-resolution audio sources, to add in the points that should exist before and after large quantities of data to smooth out the waveform and restore information lost during the digital recording. This is designed to produce detailed playback that's free of interference, expressive in the lower range, and faithful to the original sound.
Supports CD, CD-R/RW, MP3, WMA, and USB Playback
Enjoy extended playback support for your high-resolution audio collection. It will play standard CDs as well as CD-R/RWs in audio, MP3, and WMA format; or you can plug in your USB drive to listen to your DSD 2.8/5.6 MHz tracks in high-resolution.
Vibration-Resistant Design for Enhanced Audio
The vibration-resistant design helps mitigate the adverse audio effects of heavy components within amplifiers. The power transformers are installed near the bottom of the CD player and immediately above the insulators to mitigate unwanted vibration.
DAC Master Clock Design
To help the DCD-800NE accurately synchronize digital circuits, it is built with a DAC Master Clock design that treats the DAC as the master when clock signals are supplied. The master clock is immediately adjacent to the DAC, helping to suppress jitter and ensure optimal precision in D/A conversion. It serves as the reference for semiconductor operation and helps optimize digital audio circuitry.
Short Circuit Paths
The circuit patterns of this CD player are engineered to make signal paths as short as possible, helping to reduce interference between circuits and the left and right channels, thereby minimizing the adverse influences on audio signals. This helps provide a clean audio output that's transparent and faithful to the original recording.
Pure Direct Mode
This mode feeds sound directly to the amplifiers by bypassing any processing that might otherwise color the signal to help output clean, detailed, accurate audio.
Optical and Digital Coaxial Output
The DCD-800NE features one optical and one digital coaxial output to connect to the digital inputs of your amplifier or receiver.
Peter  012-2536225
Fong   016-3098668
Denon PMA-800NE Integrated Amplifier & DCD-800NE CD Player Trade
Denon PMA-800NE Specs
Amplifier
Amplifier Type    Integrated Amplifier (Preamp/Power Amp Combo)
Channels    2.0
Power Output per Channel    50 W at 8 Ohms / 20 Hz to 20 kHz / 0.07% THD
85 W at 4 Ohms / 1 Hz / 0.7% THD
Frequency Response    5 Hz to 100 kHz +0/-3 dB
THD    0.01% (8 Ohms, 1 kHz, Rated Output -3 dB)
Speaker Impedance    4 to 16 Ohms
Tone Control    Bass (100 Hz): ±8.0 dB
Treble (10 kHz): ±8.0 dB
Connectivity
Rear A/V Inputs    3 x Optical TOSLINK
1 x Digital Coaxial
4 x Stereo RCA
1 x Stereo RCA (Phono MC/MM) with Ground Screw
Rear A/V Outputs    1 x Stereo RCA
Front I/O    1 x 1/4" / 6.35 mm Headphone Output
Other Rear I/O    1 x 1/8" / 3.5 mm (IR) Input
1 x 1/8" / 3.5 mm (IR) Output
Speaker Connectors    4 x Binding Post Pair
Input Impedance    Digital Coaxial: 75 Ohms
Phono (MC): 100 Ohms
Phono (MM): 47 Kilohms
Line:
40 Kilohms (Source Direct Off)
17 Kilohms (Source Direct On)
Input Sensitivity    Phono (MC): 200 mV
Phono (MM): 2.5 mV
Line: 105 mV
Max Input Level    Phono (MC): 6 mV (1 kHz)
Phono (MM): 70 mV (1 kHz)
Phono RIAA EQ Deviation    ±0.5 dB (20 Hz to 20 kHz)
Signal to Noise Ratio    Phono (MC): 71 dB (0.5 mV Input)
Phono (MM): 86 dB (5 mV Input)
Line: 105 dB
Wireless Connectivity
Wi-Fi    None
Bluetooth    None
Power
AC Input Power    240 VAC, 50/60 Hz
Power Consumption    Active: 200 W
Standby: 0.3 W
Physical
Dimensions (W x H x D)    17.1 x 4.9 x 12.1" / 434.0 x 122.0 x 307.0 mm
Weight    16.5 lb / 7.5 kg
Packaging Info
Package Weight    19.75 lb / 8.95 kg
Box Dimensions (LxWxH)    20 x 15 x 8"
Denon DCD-800NE Specs
Compatibility
Supported Disc Types    CD, CD-R, CD-RW, Mini-CD
Supported Formats    AAC, AIFF, DFF, DSF, FLAC, M4A, MP3, WAV, WMA
General
Frequency Response    2 Hz to 50 kHz -3 dB (DSD)
2 Hz to 50 kHz -3 dB 24-Bit (PCM)
2 Hz to 20 kHz 16-Bit (PCM)
Frequency Range    2 Hz to 100 kHz (DSD)
2 Hz to 96 kHz 24-Bit (PCM)
DAC    Burr Brown PCM1795 (192 kHz / 32-Bit)
Dynamic Range    108 dB (DSD)
108 dB (PCM)
101 dB (PCM)
Signal to Noise Ratio    115 dB
Max Sample Rate/Resolution    192 kHz / 32-Bit (PCM)
5.6 MHz / 1-Bit (DSD)
Total Harmonic Distortion (THD)    0.0015% (DSD)
0.002% (24-Bit PCM)
0.0025% (16-Bit PCM)
Bit Rates    48 to 320 kb/s
Number of Channels    2
Maximum Output Voltage    0.5 Vp-p (Digital Coaxial)
2.2 Vrms
Connections
Audio Outputs    1 x RCA Stereo (L/R)
1 x TOSLINK Optical
1 x Digital Coaxial
Audio Inputs    1 x USB Type-A
Other I/O    1 x 1/8" / 3.5 mm (IR) Input
Physical
Disc Capacity    1
Power Consumption    28 W (Typical)
0.2 W (Standby)
Dimensions (W x H x D)    17.1 x 10.5 x 4.5" / 434 x 107 x 275 mm
Weight    9.9 lb / 4.5 kg
Packaging Info
Package Weight    12.65 lb / 5.73 kg
Number of posts : 876
