Denon PMA-1600NE Integrated Amplifier & DCD-1600NE SACD CD Player
Denon PMA-1600NE Integrated Amplifier & DCD-1600NE SACD CD Player Empty Denon PMA-1600NE Integrated Amplifier & DCD-1600NE SACD CD Player
Post by stylelaser.com.my Tue Sep 28, 2021 10:55 pm
Denon PMA-1600NE Integrated Amplifier & DCD-1600NE SACD CD Player  Brand New. Now Selling At RM19,799. Free Shipping Within West Malaysia.
               Denon PMA-1600NE Integrated Amplifier & DCD-1600NE SACD CD Player Es_de148
PMA-1600NE
Integrated Amp with DAC mode for high resolution audio
          Denon PMA-1600NE Integrated Amplifier & DCD-1600NE SACD CD Player Es_de150          Denon PMA-1600NE Integrated Amplifier & DCD-1600NE SACD CD Player Es_de149
适合高解析度音频的带USB-DAC的高品质集成放大器适合高解析度音频的带USB-DAC的高品质集成放大器
FEATURES - PMA-1600NE
Denon is one of the rare audio brands that continued to actively develop Hi-Fi components and accumulate, refine, and pass down Hi-Fi audio technologies. The performance of the PMA-1600NE goes well beyond that of Denon’s previous PMA-1500 series. With its ultimate built-quality, unique Denon technologies and state-of-the-art connectivity, the PMA-1600NE truly is a masterpiece of sound technology. Thanks to the rear USB-B input and embedded high quality D/A converter, the PMA plays high resolution files up to 384kHz/32bit and DSD up to 11.2MHz from a computer in impeccable sonic quality. For the best performance from analogue inputs, the PMA-1600NE features an Analog Mode which allows to switch off all unutilized sections like the digital input circuitry or the low noise display for an unaltered audio reproduction.
Denon是持续积极的开发Hi-Fi元件并积累、提炼和传承Hi-Fi音响技术的少有音响品牌之一。PMA-1600NE的性能远超Denon的上一个PMA-1500系列。凭借其极致的制造品质、独特的Denon技术和最先进的连接功能,PMA-1600NE不愧是音响技术的杰作。因为有后置USB-B输入和内置高品质D/A转换器,PMA能以完美的音质从计算机播放高达384kHz/32位的高解析度文件和高达11.2MHz的DSD。为使模拟输入能获得最佳性能,PMA-1600NE配备了模拟模式,允许关闭所有闲置部分,如数字输入电路或低噪声显示屏等,以实现原汁原味的音频再现。
State-of-the-art Denon Solutions
亮点/优点
  • 2 x 140 W (4 ohm) output - Enough power even for big rooms
  • Advanced Ultra High Current (UHC)-MOS Single Push-Pull Circuit Power Amplifier with Schottky barrier diodes - Wide bandwith sound from deep bass to detailed highs
  • DAC Master Clock Design - Jitter-free audio reproduction
  • Rear USB-B input - High Resolution Audio playback up to 384 kHz / 32 bit and 11.2 MHz DSD
  • Digital isolator to eliminate high-frequency computer noise on the USB-B or digital inputs - Enjoy all sources without any unwanted electric noise
  • FL display for source and sample rate indication - Easily capture most important information
  • Analog AMP Mode switching off digital audio circuitry and display - Pure analogue audio reproduction
  • Advanced AL32 Processing Plus - Digital recordings beautifully faithful to the original sound
  • Direct Mechanical Ground Construction - Minimizes unwanted vibration
  • Chassis construction with 6 independent blocks - Eliminates noises between the circuits
  • Main transformer with separate power supplies for analogue and digital circuits - Preserves audio signal purity
  • 2 Digital Optical and 1 Digital Coaxial inputs; High performance MM & MC Phono Equalizer Amp - Ready for music from all sources
  • Available in Premium Silver and Black - Perfectly matching the DCD-1600NE Super Audio CD Player
  • 2 x 140 W(4 Ω)输出 - 功率足以适合大房间所需
  • 带肖特基二极管的高级超高电流(UHC)-MOS单端推挽电路功率放大器 - 从低沉低音到精细高音的宽带宽声音
  • DAC主时钟设计 - 无抖动音频再现
  • 后置USB-B输入 - 高达384 kHz/32位和11.2 MHz DSD的高解析度音频播放
  • 数字隔离器可消除来自USB-B或数字输入的高频计算机噪音 - 欣赏所有源而无任何电子噪音
  • 用于源和采样率指示的FL显示屏 - 轻松捕获最重要的信息
  • 模拟AMP模式将关闭数字音频电路和显示 - 纯粹模拟音频再现
  • Advanced AL32 Processing Plus - 数字记录尽善尽美地忠实于原始声音
  • 直接机械接地结构 - 最大程度减少意外振动
  • 带6个独立区间的底盘结构 - 消除电路之间的噪音
  • 用于模拟和数字电路的带独立电源的主变压器 - 保留音频信号纯度
  • 2个数字光纤和1个数字同轴输入;高性能MM和MC唱头均衡放大器 - 可应付来自所有源的音乐
  • 提供高级银色机身 - 完美匹配DCD-1600NE SACD播放机
DCD-1600NE
Super Audio CD Player bringing disc playback performance to remarkable heights
          Denon PMA-1600NE Integrated Amplifier & DCD-1600NE SACD CD Player Es_de151          Denon PMA-1600NE Integrated Amplifier & DCD-1600NE SACD CD Player Es_de152
高品质SACD播放机将光盘播放性能提升到非凡的高度
FEATURES - DCD-1600NE
特点 - DCD-1600NE
Denon is one of the rare audio brands that continued to actively develop Hi-Fi components and accumulate, refine, and pass down Hi-Fi audio technologies. The DCD-1600NE focuses on achieving the essence of a disc player: ultra-high precision in reading discs and supplying high-quality audio signals to the amp. To achieve this, the signal paths are as short as possible and the whole circuitry is minimized. The engineers also redesigned the disc drive mechanism brackets and the chassis to eliminate vibration, the great enemy of disc players, and achieve ultra-vibration-resistant performance. The information on the disc is now read with impeccable accuracy and a clean, high-grade signal is supplied to the DCD-1600NE’s Advanced AL32 Processing Plus circuitry. Besides CD and Super Audio CD playback, the DCD features playback of audio recordings up to PCM192/24 or DSD5.6 recorded on a DVD R/RW for full flexibility and extended access to high resolution audio.
Denon是持续积极的开发Hi-Fi元件并积累、提炼和传承Hi-Fi音响技术的少有音响品牌之一。DCD-1600NE专注于光盘播放机的根本功能:超高精度读取光盘和为放大器提供高品质音频信号。为实现这一目标,将信号路径尽可能缩短并最大程度缩小整个电路。工程师们还重新设计了光盘驱动机构支架和底盘以消除振动(光盘播放机的大敌)并实现超强抗振性能。现在可以以完美的精度读取光盘上的信息并向DCD-1600NE的Advanced AL32 Processing Plus电路提供清晰的高质量信号。除了能播放CD和SACD外,DCD还能播放DVD R/RW上录制的高达PCM192/24或DSD5.6的音频录音,实现充分的灵活性并拓展对高解析度音频的支持。
亮点/优点
  • Advanced AL32 Processing and Ultra Precision 192kHz/32bit D/A Converter - Digital recordings beautifully faithful to the original sound
  • DAC Master Clock Circuit Design - Jitter-free audio reproduction
  • Carefully designed construction, minimum signal paths and selected Hi-Fi parts - Preserves audio signal purity
  • Denon original drive mechanism with S.V.H. loader - Accurate pickup and decoding from all discs
  • Playback of CD and Super Audio CD; DSD (2.8 MHz / 5.6 MHz) files and PCM files up to 192 kHz / 24 bits recorded on DVD R/RW - Extended disc support for modern high-res audio
  • Separated digital and analogue power supply - Preserves audio signal purity
  • Pure Direct Mode - For clean output
  • Available in Premium Silver and Black - Perfectly matching the PMA-1600NE Integrated Amp
  • Advanced AL32 Processing和Ultra Precision 192kHz / 32位数模转换器 - Digital recordings beautifully faithful to the original sound
  • DAC主时钟电路设计 - Jitter-free audio reproduction
  • 直接机械接地结构 - Minimizes unwanted vibration
  • 精细设计的结构、最小信号路径和精选高保真部件 - Preserves audio signal purity
  • 带有S.V.H.装载器的Denon原装驱动机构 - Accurate pickup and decoding from all discs
  • 可播放CD和SACD、DVD R/RW上刻录的DSD (2.8 MHz / 5.6 MHz)文件和高达192 kHz / 24位的PCM文件 - Extended disc support for modern high-res audio
  • 独立的数字和模拟电源 - Preserves audio signal purity
  • Pure Direct模式 - For clean output
  • 提供高级银色机身 - Perfectly matching the PMA-1600NE Integrated Amp
               Denon PMA-1600NE Integrated Amplifier & DCD-1600NE SACD CD Player Es_de153
Denon PMA-1600NE Specs
Amplifier
Amplifier Type    Integrated Amplifier (Preamp/Power Amp Combo)
Channels    2.0
Power Output per Channel    70 W at 8 Ohms / 20 Hz to 20 kHz / 0.07% THD
140 W at 4 Ohms / 1 Hz / 0.7% THD
Frequency Response    5 Hz to 100 kHz +0/-3 dB
THD    0.01% (8 Ohms, 1 kHz, Rated Output -3 dB)
Speaker Impedance    4 to 16 Ohms
Tone Control    Bass (100 Hz): ±8.0 dB
Treble (10 kHz): ±8.0 dB
Connectivity
Rear A/V Inputs    2 x Optical TOSLINK
1 x Digital Coaxial
1 x USB Type-B
3 x Stereo RCA
1 x Stereo RCA (Phono MC/MM) with Ground Screw
Rear A/V Outputs    1 x Stereo RCA
Front I/O    1 x 1/4" / 6.35 mm Headphone Output
Other Rear I/O    1 x 1/8" / 3.5 mm (IR) Input
1 x 1/8" / 3.5 mm (IR) Output
Speaker Connectors    4 x Binding Post Pair
Input Impedance    Phono (MC): 100 Ohms
Phono (MM): 47 Kilohms
Line:
47 Kilohms (Source Direct Off)
23 Kilohms (Source Direct On)
Input Sensitivity    Phono (MC): 0.2 mV
Phono (MM): 2.5 mV
Line: 125 mV
Max Input Level    Phono (MC): 10 mV (1 kHz)
Phono (MM): 130 mV (1 kHz)
Phono RIAA EQ Deviation    ±0.5 dB (20 Hz to 20 kHz)
Signal to Noise Ratio    Phono (MC): 74 dB (0.5 mV Input)
Phono (MM): 89 dB (5 mV Input)
Line: 108 dB
Wireless Connectivity
Wi-Fi    None
Bluetooth    None
Power
AC Input Power    120 VAC, 60 Hz
Power Consumption    Active: 295 W
Standby: 0.2 W
Physical
Dimensions (W x H x D)    17.1 x 5.3 x 16.1" / 434.0 x 135.0 x 410.0 mm
Weight    38.8 lb / 17.6 kg
Packaging Info
Package Weight    44.65 lb
Box Dimensions (LxWxH)    21 x 20 x 10"
Denon DCD-1600NE Specs
Compatibility
Supported Disc Types    CD, CD-R, CD-RW, SACD, DVD+R, DVD+RW, DVD-R, DVD-RW
Supported Formats    AAC, AIFF, DFF, DSF, FLAC, M4A, MP3, WAV, WMA
General
Frequency Response    2 Hz to 50 kHz -3 dB (SACD)
2 Hz to 20 kHz (CD)
Frequency Range    2 Hz to 100 kHz (SACD)
2 Hz to 20 kHz (CD)
Dynamic Range    112 dB (SACD)
101 dB (CD)
Signal to Noise Ratio    117 dB (CD)
119 dB (SACD)
Max Sample Rate/Resolution    44.1 kHz (CD)
2.8 MHz (SACD)
Total Harmonic Distortion (THD)    0.0016% @ 1 kHz (CD)
<0.001% @ 1 kHz (SACD)
Bit Rates    32 to 320 kb/s
Number of Channels    2
Rated Output / Impedance    2 V / 10 Kilohms
Connections
Audio Outputs    1 x TOSLINK Optical
1 x Digital Coaxial
1 x RCA Stereo (L/R)
Other I/O    1 x 1/8" / 3.5 mm (IR) Input
Physical
Power Consumption    0.1 W (Standby)
24 W
Dimensions (W x H x D)    17.1 x 5.3 x 13" / 434 x 135 x 329 mm
Weight    18.1 lb / 8.2 kg
Packaging Info
Package Weight    22.75 lb
Box Dimensions (LxWxH)    22 x 18 x 10"
Number of posts : 875
