Modwright KWA 150 Power amp (Used)
Modwright KWA 150 Power amp (Used) Empty Modwright KWA 150 Power amp (Used)
Post by hifidelity Fri Oct 08, 2021 10:05 am
ModWright KWA 150 Stereo Power Amplifier
Power output: 150W @ 8 ohm (stereo); 250W @ 4 ohm (stereo); 450W @ 8 ohm (bridged mono); 650W @ 4 ohm (bridged mono)
Bandwidth: 10Hz–100kHz (+0, -1dB)
Distortion: 0.06% THD @ 150W into 8 ohms; 0.06% THD @ 250W into 4 ohms
Channel Separation: -75dB below 20kHz
Gain: 26dB
Signal to Noise Ratio: -100dB unweighted
Input Impedance: Minimum of 15k at 50Hz; 23k at 1kHz
Output Impedance: 0.076 ohm
Damping Factor: 105 into an 8-ohm load (averaged across measurements at 100Hz, 1kHz, and 10kHz)
Dimensions: 17″ x 17″ x 8.5″
Weight: 74 lbs.
Condition is 8/10. New price was USD6000 but now asking for Rm11800 neg. Any question do free to call Steven at 0122889393. Thank you
Modwright KWA 150 Power amp (Used) 20211007_193041Modwright KWA 150 Power amp (Used) 20211007_193044Modwright KWA 150 Power amp (Used) 20211007_193049
hifidelity
Number of posts : 928
Modwright KWA 150 Power amp (Used) Empty Re: Modwright KWA 150 Power amp (Used)
Post by hifidelity Mon Nov 01, 2021 1:22 pm
hifidelity
Post by hifidelity Tue Jun 21, 2022 5:29 pm
hifidelity
