Luxman A-353 Integrated Amplifier (Price Reduce)
Luxman A-353 Integrated Amplifier (Price Reduce) Empty Luxman A-353 Integrated Amplifier (Price Reduce)
Post by Jason Eng Wed Oct 20, 2021 4:54 pm
** No Remote/ No Box **
Condition: 8/10 Still Working
Prices: RM1480/= RM1380 Negotiable
Calls or Whatsapp: 0174365998
Postage can be arrange.
https://www.youtube.com/watch?v=v_pn9RACREQ
https://www.youtube.com/watch?v=Se0n9PyY7vA
Generally
Manufacturer: Luxman
Model: A-353
Model range: 300 series
Type: Stereo integrated amplifier
Years of construction: 1994 - 1998
Color: front champagne-colored (type G), housing cover anthracite, also available in black (type B)
Remote control: yes, system bus
Power consumption:
Dimensions (W / H / D): 438 mm x 127 mm x 369 mm
Weight: 9 kg
connections
Entrances:
Phono (MM / MC switchable on the back):
Phono MM: 2.5mV / 47kOhm, 220mV max. (1kHz, RMS)
Phono MC: 200µV / 100 Ohm
Tuner: 150mV / 47kOhm
CD: 150mV / 47kOhm
Tape Play 1, 2: 150mV / 47kOhm
DAT: 150mV / 47kOhm
Outputs:
Tape Rec 1, 2:
System bus 1, 2:
Headphones:
2 pairs of speakers
Technical specifications
Continuous output (with distortion factor)
8 Ohm: 2x 80 W (20Hz - 20Khz)
4 ohms: 2x 105 W.
Dynamic performance
8 ohms: 2x 100 W.
6 ohms: 2x 110 W.
4 ohms: 2x 125 W.
Frequency response:
Phono MM: 20 Hz - 20 kHz (± 0.3 dB)
Phono MC: 20 Hz - 20 kHz (± 0.5 dB, 100 Ohm)
High level: 10 Hz - 70 kHz (+0.2 / -0.8 dB)
Total harmonic distortion: <0.008%
Signal-to-noise ratio:
Phono MM: 82 dB
Phono MC: 62 dB
High level: 100 dB
Tone control:
Bass: ± 10 dB at 100 Hz
Treble: ± 10 dB at 10 kHz
Subsonic filter:
Special equipment
Controls for bass, treble and balance
Rec Out selector
Loudness switchable
Stereo / mono switchable
"Line Straight" switch for direct switching through of the signal source, bypassing the preamp
Line phase sensor
Headphone output
remote control
System bus for controlling other Luxman components (including CD-Synchro Start)
Luxman A-353 Integrated Amplifier (Price Reduce) Luxman10
Luxman A-353 Integrated Amplifier (Price Reduce) Luxman11
Luxman A-353 Integrated Amplifier (Price Reduce) Luxman12
Luxman A-353 Integrated Amplifier (Price Reduce) Luxman13
Jason Eng
Regular
Regular
Number of posts : 72
Registration date : 2020-09-09
Luxman A-353 Integrated Amplifier (Price Reduce) Empty Re: Luxman A-353 Integrated Amplifier (Price Reduce)
Post by Jason Eng Mon Oct 25, 2021 3:14 pm
Jason Eng wrote:Luxman A-353 Integrated Amplifier
Generally
Model: A-353
Power consumption:
Weight: 9 kg
connections
Entrances:
CD: 150mV / 47kOhm
DAT: 150mV / 47kOhm
Outputs:
Tape Rec 1, 2:
System bus 1, 2:
Headphones:
2 pairs of speakers
4 ohms: 2x 105 W.
Dynamic performance
8 ohms: 2x 100 W.
6 ohms: 2x 110 W.
4 ohms: 2x 125 W.
Frequency response:
Phono MM: 82 dB
Phono MC: 62 dB
High level: 100 dB
Tone control:
Subsonic filter:
Special equipment
Rec Out selector
Loudness switchable
Line phase sensor
Headphone output
remote control
Jason Eng
Regular
Regular
