JL Audio Gotham G213 v2 Subwoofer
JL Audio Gotham G213 v2 Subwoofer Empty JL Audio Gotham G213 v2 Subwoofer
Post by andlcl Sun Oct 31, 2021 12:07 pm
[size=36]JL Audio Gotham G213 v2 Subwoofer Jl_got11
[/size]
JL Audio Gotham G213 v2 Subwoofer Jl_got12
Price: RM58,800.00
(Note: Brand new unit is selling at RM88,000.00)
Contact: 012-2053418
JL AUDIO GOTHAM G213 V2
4500 WATTS. 360 POUNDS. DEVASTATING BASS. LISTENING TO A GOTHAM V2 REVEALS AN ENTIRELY NEW DIMENSION OF SUBWOOFER PERFORMANCE... A DIMENSION SO SATISFYING THAT LISTENING TO LESSER SUBWOOFERS WILL FOREVER BECOME AN ACT OF COMPROMISE.
Your first look will tell you that you are looking at something special... your first listen will confirm it beyond a shadow of a doubt.
The beauty of the Gotham v2 extends well beyond its exotic design and exceptional craftsmanship, aiming right at the emotional core of musical and cinematic enjoyment. This is a subwoofer system with limits that exceed the needs of the typical home theater application, delivering a weight and integrity of reproduction that can only come from a system that is always in control. Its allure lies as much in its ability to convey subtleties as in its prodigious output capabilities. It is simply devastating.
A luxurious, handcrafted gloss-black finish is complemented by machined aluminum and stainless steel accents for a look and feel that fits perfectly with the finest home furnishings. More importantly, the beautiful cabinet houses a pair of JL Audio's highest-technology subwoofer drivers. When demanded by program material, the Gotham's prodigious switching amplifier can deliver 4500 watts of RMS power, to take full advantage of the twin drivers' four inches of peak-to-peak excursion capability. This ensures that the Gotham can breeze through material that makes other subwoofers go into clipping, limiting or distress.
A very complete set of signal processing features is easily accessible on the top surface of the Gotham. These include a highly flexible low-pass filter, variable phase, switchable polarity, e.l.f. trim and our powerful Digital Automatic Room Optimization (D.A.R.O.) system. A calibrated microphone is included for the D.A.R.O. system. Input connections are made via unbalanced RCA connections or balanced Neutrik combo XLR/TRS jacks. Also included is an XLR output to connect a second Gotham v2 as a slave unit.
Frequency response (+/- 1.5 dB, -3 dB): 19 Hz to 112 Hz, 17.5 Hz to 120 Hz
Amplifier power: 4,500 W RMS short term
Inputs: 2 x RCA for stereo or mono, 2 x XLR balanced for stereo or mono
Filter: Low pass, 12/24 dB/octave, defeatable, 30 Hz to 130 Hz
Polarity: 0 or 180 degrees
Phase: Variable, 0-270 degrees
Extreme Low-Frequency Trim: -12 dB to +3 dB at 20 Hz
Output to slave: 1 x male XLR, balanced
Calibration mode: Digital Automatic Room Optimization, includes laboratory-grade microphone
Dimensions (WHD): 21.5" x 34.13" x 24"
Weight: 360 lb
andlcl
Number of posts : 107
Registration date : 2017-05-01
